Hymer/Reich Tandem submersible pump (1 Viewer)
Sep 26, 2010
611
364
North Wales
Hymer B654
Since 2009
Hi all!
I drained down the water system in December and today partly refilled the fresh water tank to flush through and test the system for the season.
In addition to water coming out of the taps (and at reduced pressure for the kitchen tap), water is also coming out of the ventilation hole (I think this is what it is?) on the top of the pump.
Has anyone experienced this please?
I can only think that either:
a) I've somehow acquired a partial blockage in the pipes over the winter and the water pressure is causing a sort of blowback through the pump (not easy to test or locate I don't think?), or
b) the pump is faulty.
Any help/advice would be appreciated,
John
Jul 29, 2013
9,069
18,480
Salisbury
Hymer B678DL A class
since 2011
Hi there we are in Spain at present in our Hymer Exsis we have the same problem I took out pump to see if I could sort it out but they are sealed it had started to work intermittently and has now completely packed up have been in touch with dealers who have ordered a new pump.they are around £40 to buy.
johnandi
Sep 26, 2010
611
364
North Wales
Hymer B654
Since 2009
Thanks Alan, I'm suspecting - and almost hoping as it's more accessible - it's the pump but exploring other possible avenues before I commit to buy.
Enjoy your time in Spain and the weather of course!
Jul 29, 2013
9,069
18,480
Salisbury
since 2011
Thanks we are going to wing it without a pump until we return to UK just have to carry a
few bottles of water.
Jan 27, 2009
872
3,359
Leyland Lancs
since 2001
One of the 'problems' I encountered after refilling with water after a winter drain-down and created a low flow situation, was my failure to reset the 'Auto Drain Valve' on the boiler.
johnandi
Sep 26, 2010
611
364
North Wales
Hymer B654
Since 2009
Yes, thanks. I thought I'd sorted it when I noticed the boiler trip valve was open. However, closing it hasn't unfortunately fixed the problem.
The pump actually pumps water well when disconnected from the system - but then again, in this situation it's not under any external pressure.
Jul 29, 2013
9,069
18,480
Salisbury
since 2011
Mine did the same when out of the system
Feb 16, 2013
19,725
51,974
uttoxeter
ambulance conversion
50 years
No expert on this but have the same pump in ours and bought a new one for spare and you can get one without a anti return valve or one with one, if you have the one with the anti return valve , has it stuck and letting your pressure escape, only guessing (y)
johnandi
Sep 26, 2010
611
364
North Wales
Hymer B654
Since 2009
Hi. I'm not sure to be honest but suspect it's not an anti-return valve problem as it pumps well when disconnected from system - but, will take it out and investigate further tomorrow.
Jul 29, 2013
9,069
18,480
Salisbury
since 2011
Thanks but I think my pump has somehow got something in it which is stopping the vanes turning as it worked intermitantly for a while before packing up all together
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
The Reich tandem pump fitted to Hymers has two separate pump barrels inside - hence the name. They are designed so that if one pump unit fails, the other will continue to work but the pump will deliver reduced pressure. Perhaps one barrel suffered frost damage? I try to remember to shake my pump after draining down for winter to get water out.
Alternatively, perhaps it has stuck; might be worth tapping it gently and trying again. One other thought; try switching over the cable connectors on the terminal block that supplies the pump.
Jul 29, 2013
9,069
18,480
Salisbury
since 2011
Thanks @JeanLuc ill try that but fear the pump is up the creak.
johnandi
Sep 26, 2010
611
364
North Wales
Hymer B654
Since 2009
Hi JeanLuc, thanks for your advice. I've tried your suggestions this morning including removing and tapping (with a moderately sized hammer!) the sides of the pump but all to no avail.
Water spouts out of the 2 vent holes whilst in operation and the pump just doesn't sound normal.
The supply is reversed (brown to blue, etc) but from reading other blogs this is apparently quite normal.
So, think I'll take the plunge (pun intended!) and opt for a new pump.
Not sure whether the current one has a none-return valve fitted, suspect it has as water runs back into the tank when I disconnect its outlet pipe. Any other way of determining whether it has a valve and does it make a difference anyway when buying a new one?
Jul 29, 2013
9,069
18,480
Salisbury
since 2011
@johnandi Thanks for the feedback, I was going to as you have but after your trial I don't think I'll bother as it was sounding cranky last time it worked and wait for a new one when we get back.
scotjimland
2,302
9,957
A Woosh bang
@Speve If you decide on a new pump I bought mine here.. Broken Link Removed
he also sells the NR valve
edit.. Philip beat me with a better price..
Jul 29, 2013
9,069
18,480
Salisbury
since 2011
:drinks:@scotjimland Thanks for that but the van is still under warranty so Hymer are going to sort it for me.
