Johnnie Gee
Went into our 624 to check things over and found the pipe coming from the tap had been pushed out by frost.
I removes the tap which wasn't easy, and found that there is a small grub screw at the back of the tap body, this allows a small plastic locating dowel to be retracted.so the pipe can be reinserted. ( so I didn't need to take the tap out in the first place.)
On my first trip away this year the tap stopped working, or should I say there was very little water coming out from either circuit. I checked the microswitch by shorting the two leads to the pump and the pump started which indicated that the microswitch had thrown its hand inoh:
I was at Camac Valley site in Dublin at the time, and had plenty of time on my hands so I went in search of the nearest motorhome repair shop which turned out to be about 20k's away.
It was a bugger to find but the guy was very friendly and helpful..even gave me a second hand microswitch for free, showed me an easier way to do the repair.
The tap isn't in the best of nick and I need to replace it really, does anyone know of a supplier for these taps as I'll need a second mortgage if I go to brownhills
JJG
JJG
