Hymer Lights (1 Viewer)
Brian Hewitt
23
29
Llandysul
13yrs
Hello All, I am a brand new member and already I am looking for help. I have a 2005 Hymer B584 (smiley) and have just had an MOT failure because of the headlight beam directions. It has passed for the last 8 years but now the same garage has a new Tester and he will not pass it. The van is a LHD import. CAN ANYONE HELP ; do you have any solutions as to how to fix the problem please. From Brian.
countryman
40
48
suffolk
Perhaps if you put some black tape on the lense just of center,it will deflect the beam,i am surprised the garage did not recomend this.
Feb 22, 2011
9,762
20,115
Newcastle under Lyme
Hymer B544 A Class
Since 2015
Have you got a hymer handbook. I think there are instructions in there for beam adjustment. There have been threads on here before but can't remember how to do it.
funflair
19,303
30,068
Guisborough
MORELO palace
since 2012
If it's got the round hella lights they are adjustable for LH or RH, some are not easy to get at though so beam benders might be easier.
To adjust you need to remove a screw and slacken a couple of others and then turn the unit.
Martin
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
The dipped units are adjustable for left and right hand driving. There are three self-tapping screws around the rim of the rear of the lamp housing. Slacken these then the housing should rotate a few degrees in the direction marked 'L' or 'R' on the rim. Be warned that the screws are a devil to access.
funflair
19,303
30,068
Guisborough
MORELO palace
since 2012
As above but one screw needs to come right out, see the spare hole at the top of the attached photo.
Sorry couldn't find a back view.
Martin
JeanLuc
3,304
2,199
Warwickshire
Thanks for the info Funflair - perhaps that's why I have never been able to get mine to rotate; although I have not had much success in accessing the screw towards the bottom of the housing. I think it is obscured by the electric levelling adjuster.
funflair
19,303
30,068
Guisborough
MORELO palace
since 2012
I wouldn't like to do them blind, our units come out once you take off the external surrounds which are held by two wing nuts inside, then its pretty easy, you do have to wind the other two screws a good way back as the light unit needs to lift off its seal to turn position.
Martin
Nov 4, 2011
5,920
38,676
Uk
I leave the two hard to get too screws loose so only need to loosen the top screwand turn lamp holder and do one screw tight
Portland
923
1,424
Conwy
C class
20 years
I adjusted mine but I removed the bumper so I could reach the screws from below its not so hard as it sounds but you take out the lock and loosen the others to rotate
Lenny HB
53,309
149,502
On the coast in West Sussex
Hymer B678 DL
The are only adjustable between left hand kick up for LHD or flat dipping which is aceptable to both VCA and for MOT. Sorry Philip just being pedantec.
I didn't realize there should be screws involved. Mine turn freely by hand. I've no idea how I could get a screwdriver in there and position it on a screw.
Earlier models with the classic Hella units have the screws, the later Almond Eyes have the later Hella unit that just needs a lever moving.
B
Brian Hewitt
23
29
Llandysul
13yrs
Hey you guys, what a response. Hopefully I will be able to get something sorted with all this advice. Many many thanks. Brian.
B
Brian Hewitt
23
29
Llandysul
13yrs
Hi Countryman, I am told that following a MOT ruling, you can no longer use deflectors during an MOT test. This is what my garage USED to do prior to this new(ish) ruling. Hey Ho. Brian.
countryman
40
48
suffolk
Hi Brian,had MOT a few weeks ago,headlamp deflectors were fitted and passed,so perhaps it is very a very recent ruling,Thanks for the tip.
B
Brian Hewitt
23
29
Llandysul
13yrs
Hi Countryman, This ruling by MOTransport came in around4/5 years ago. I think you were very lucky to have your van passed and wished I was In your neck of the woods to use your garage. BH
B
Brian Hewitt
23
29
Llandysul
13yrs
Hi again, is your van a left hooker?. That is where my problem lies because the lights are set for driving on the right.. Just a thought. BH
countryman
40
48
suffolk
Hi Brian ,no my Hymer is a right hand drive,B754.Happy travels.
Nov 4, 2011
5,920
38,676
Uk
I've just had my Hymer MOT'ed and when I went to collect it the tester told me the lights kicked up at the side the wrong way, so he had put some tape on and passed it, he also said I could take tape off when I go and get the vano_O
rikfos
315
199
hereford
coachbuilt
For the past 5 years my vehicle has passed despite having deflector strips fitted
Apr 15, 2015
600
1,034
Whitchurch, Shropshire
Carthago E-Line 50
Since May 2011
A link to the MOT Manual
Link Removed
Section 1.8 deals with headlamp aim. It says that tape on the headlamp is not a reason for rejection (with some conditions).
As far as I'm aware it's the latest version of the manual.
Mike
Jaws
23,832
72,342
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Time to find a proper MOT place then ! One that is not just after making a few bob !! LOL !!
Hymie
810
1,005
Essex
Classic Hymer B564
Since 1981
Had our MOT on 14th Oct with deflectors fitted, passed fine with no probs
Hymie.
B
Brian Hewitt
23
29
Llandysul
13yrs
Hi to everyone on this damp shortest day of the year. I just wanted to wish everyone a very merry xmas and a happy travelling New Year from Jane and myself and Meila the red collie pup. Cheers All.
