My Hymer is LHD and has just failed its MOT as the lights are set-up for continental driving. Does anyone know how to adjust the Hella lamps or should I use Beam Deflectors as a short term fix?
I'm told that the small size of the lamp (~90mm) may be an issue for placement of the beam deflector and in some cases can cause over heating (its not LED).
I'm also told that rotating the lamp 180 deg may not be a simple solution as the beam pattern is more than just left/right alignment.
What does everyone else do?
Colin
Colin
