Hymer/Fiat Ducato headlights
Discussion in 'Motorhome Chat' started by reynardracer, Sep 23, 2015.
  1. reynardracer
    reynardracer Funster
    Aug 10, 2015
    65
    7
    Twyford
    Just driven my Hymer in the dark and OMG where are the headlights. Does anyone else have this issue or know how to re-align the headlights. Model is 2000 Hymer B644.
    Peter
  2. Figaro
    Figaro Funster
    Feb 22, 2011
    1,063
    828
    Newcastle under Lyme Staffordshire
    The headlights are the round glass things on the front, try switching them on before thing about re-alignment !
    • Like it Like it x 2
  3. reynardracer
    Aug 10, 2015
    65
    7
    Twyford
    Very funny (not)
  4. Figaro
    Figaro Funster
    Feb 22, 2011
    1,063
    828
    Well, explain a little more fully, do they not work at all, do they work but point skyward, or can`t you find the on / off switch ?
    Driving in the dark with no lights not recommended
  5. reynardracer
    Aug 10, 2015
    65
    7
    Twyford
    They were on but may have well not been. Previous owner mentioned that they could be reset for LHD but having just passed an MOT I must assume that they were aligned correctly. Right hand side just seemed to point at the ground. High beam, inside ones were OK, but low beam were dreadful.
  6. Figaro
    Figaro Funster
    Feb 22, 2011
    1,063
    828
    I`m sure the techies will be along to give some advice, strange it passed the MOT if they are as bad as you describe.
    What sort of lights are they, the four small round type, hella I think they are called, stand to be corrected.
  7. reynardracer
    Aug 10, 2015
    65
    7
    Twyford
    Yes they are the four small round ones.
  8. campa cola
    campa cola Funster
    Oct 5, 2012
    2,991
    5,876
    Weegeland
    Even on a lh alignment the lights should still be bright. You may have an alternator charging problem.
  9. Box Boy
    Box Boy Funster
    Jul 3, 2014
    95
    57
    West Sussex
    Slightly off topic, but just had MOT for my Fiat and all ok but for a 'Fail' because of too low head beam! :mad: Then on reverse of print- out a 'Pass' after the lights had been adjusted from inside the cab by the tester with the toggle provided! :confused: My van is nose down and I had arrived for the test with none of the usual weight at rear to bring the lights up. Apparantly testers are not allowed to adjust the lights whilst under test and have to register a 'Fail' after which they can adjust accordingly.:rolleyes::rolleyes: Off this weekend to Cornwall :cool: so after loading up I will have to re-adjust my headlamps! :rolleyes:
  10. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,779
    10,197
    changing LHD to RHD orientation is a case of rotating the bulb holder assembly behind the light. It is possible to slacken the screws just enough to allow rotation, but its so difficult accessing the screws that often owners leave them just tight enough. maybe the bulbs are between positions? either way they should be bright. check the bulbs are not old and dimming or even failed and that the alternator is charging well
  11. reynardracer
    Aug 10, 2015
    65
    7
    Twyford
    This sounds the most plausible reason. I will have to check out the position of the bulb holder. Thanks for the help.
  12. Manic
    Manic Funster
    Nov 4, 2011
    1,052
    1,181
    Uk
    I had a problem with one of my dipped beam lights keep pointing to the ground (I could tell when it had moved because it didn't look right in the body), it was coming off its ball joint mounting. I secured it with the old faithful cable tie, I will see if I can get a picture later.
