Hymer Exsis-1 Headlights
Discussion in 'Hymer' started by wanderer, Dec 4, 2014.
  1. wanderer
    wanderer Funster
    Apr 14, 2008
    452
    420
    huntingdon
    The camper on the next pitch to me in Spain has experienced a headlight lens exploding on the way down . It is a Hella complete unit replacement cost approx. £1500 as far as he is aware the damage was not caused by any external missile and there is history of these exploding lights on Hymers . He is still under waraenty (vehicle 18 months old) has anyone claimed for a headlight through warranty or vehicle insurance ??
  2. Judge Mental
    Judge Mental Funster Deceased RIP
    Sep 2, 2009
    6,782
    6,037
    Sarth London
    Blimey..will let my mate know:cautious:
  3. Xabia
    Xabia Funster
    Jan 20, 2011
    795
    523
    Rural Nottinghamshire and Spain
    I have heard that other people have contacted Hymer when they had the same problem and that the unit was replaced FOC, even shortly out of warranty.
    After hearing of these problems I put Lamin-X film on my lights and have not had a problem in 30,00 ish miles, just hope I haven't tempted fate by this post!
    Mike
    • Like it Like it x 2
  4. bigfoot
    bigfoot Funster
    Dec 23, 2007
    4,016
    5,343
    Wirral
    It happened on my 2010 exsis.
    Travelworld replaced it under warranty, my vehicle was also 18 months old.
    Apparentlu it is the left hand side unit that is faulty. All they wantef was a picturr of the rear of the unit with any reference numbers on the back.
    I bought the van from Brownhills, but Travelworld picked up the wattanty work.
  5. Detnor
    Detnor Funster
    May 12, 2011
    563
    510
    My headlight exploded on the drive when the van was stationery, 1 year out of warranty. Travelworld, who I had never dealt with, arranged a foc warranty replacement. It is a well documented issue, no idea to the cause. I removed the day running lights as I found the lens gets very hot, one day I'll source led replacements.
  6. SIFTA SAM
    SIFTA SAM Funster
    Jan 27, 2009
    482
    493
    Leyland Lancs
    Seem to remember some time ago, Hymer admitted that some of this type of Hella lamp had been fitted 'under mechanical stress'
  7. Wobby
    Wobby Read Only Funster
    Aug 26, 2007
    83
    55
    Hailsham
    I've done the same, only problem was had to order Lamin-X film from USA
  8. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,929
    6,828
    West Sussex
    One of the Guys in the Hymer club used to make some polycarbonate covers for them, he doesn't make them anymore so I made my own.
    Takes less than an hour to make a pair, cut to shape from 2mm UV proof polycarbonate, drill holes to fit suckers to hold on to headlamp also fitted a couple of ties using clear strimmer wire in case suckers failed, cost less than £25. Using the suckers gives about a 3 P1000038.jpg
    The films are really to stop the glass going all over the road if the lamp shatters it may offer a bit of protection but not much.
    If you do get a lamp go and not claiming on insurance they are only about €1000 in Germany.
  9. nuttall-smith
    nuttall-smith Read Only Funster
    Feb 19, 2015
    5
    stokenham kingsbridge devon
    Many thanks for the reply, I think making them is the answer, all the lights that shattered I assume were on Hymer A class prior to 2015 so perhaps the new ones don't have the same problem, touch wood.
  10. wanderer
    wanderer Funster
    Apr 14, 2008
    452
    420
    huntingdon
    Travelworld are replacing the shattered headlight under warranty excellant service
    • Like it Like it x 1
  11. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,929
    6,828
    West Sussex
    I appeared to be a problem with the left hand lamp from 2006 - 2009.
  12. muddywellies
    muddywellies
    Jul 6, 2014
    32
    55
    Varies in Europe
    I like the idea of protecting the lights with 2mm Lexan (solid polycarbonate). Granted, there's nothing to do if the bulb explodes! But, I reckon it would be a wise precaution at any time, for any any age of vehicle. Though I think I will use white Sikaflex 212 to attach after cutting out....
  13. nuttall-smith
    Feb 19, 2015
    5
    Thanks for the reply, if you use Sikaflex 212 wouldn't the cover become permanently attached which is fine until the cover gets damaged itself. What a pessimist I am!!!
  14. nuttall-smith
    Feb 19, 2015
    5
    What explodes, is it the bulb or the glass cover or does the exploding bulb break the outer glass?
  15. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,929
    6,828
    West Sussex
    If you use suckers you get an air gap and easy to remove for cleaning, if you are going to use an adhesive it needs to be clear or it will look dreadful.
  16. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,929
    6,828
    West Sussex
    It's the glass that explodes, there was a manufacturing fault on the early ones.
  17. SandraL
    SandraL Funster
    Jan 24, 2012
    312
    160
    Somerset
    @Lenny HB Like the idea of the perspex cover. Did you have to warm it to get curve of lamp, if so oven, hot air gun? How are suckers attached to the perspex? Have seen some suggest using threaded suckers that take a bolt but can't see that in the picture. Have small stone chip in ours so I think I need to take action. Thanks in advance.
  18. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,929
    6,828
    West Sussex
    You need to use polycarbonate not perspex I used Lexan, 2mm is thin enough to follow the curve of the lamps without any heating, you can use suckers wth screws I prefer the ones that push in. I used an under size hole so they were a struggle to get in but will never come out. Also put a loop of thin clear strimmer line around the back of the lamps so if the suckers gave way I don't lose the cover.
    Lexan Polycarbonate
    Suckers
    Clear Strimmer line - Poundland
    • Useful Useful x 1
  19. SandraL
    SandraL Funster
    Jan 24, 2012
    312
    160
    Somerset
  20. SandraL
    SandraL Funster
    Jan 24, 2012
    312
    160
    Somerset
    I'll try again, excellent info Lenny, a little job for when we get home. Thanks
