- Aug 18, 2014
- 23,742
- 133,210
- Transit PVC
- 16 years since restarting
Good point jetlag03, but I don't know the answer
Under the driver's seat at the rear of the EBL, see the following photos -
The electrical set-up with the seat removed. Notice one of the silver screw heads is rust brown (bottom right of center), all the others still have their original coating
From the opposite side with the auto box computer moved to one side and the front support bar for the computer removed
Close-up of the 10mm2 Black + and Brown - cables originating at the rear of the EBL running directly to the 2 hab batteries. There is a 50A fuse in the line as the cables emerge in hab battery box, this fuse was not blown. The second 10mm2 Brown cable and the matching Red cable (charging cables for the starter battery) were singed but the insulation for these had not been damaged.
A clearer photo showing the cables had about 50% burnt away and the fuse didn't blow, is it too high a value? Also have to say that for some reason it looks as though this has happened over a long period of time, and the fact that it had only travelled 8000 miles before we bought it meant that the chafing had happened slowly. Only after trying to find the reason for the starter battery to suddenly expire did I gently try to move the cables under the seat and saw the puff of smoke.
In reality we got lucky, if this had made a good contact with earth while connected to the batteries while we were travelling or another time it could have been a fire that would have been hard to stop as you can't access this area quickly if at all in a hurry.
That is the screw for the third support bar that has damaged the cable & gradually shorted it out due to vibration/movement.
