Hymer B680 Built 2005 on a MB 416CDI
Preparing to fit 3 new batteries today and a couple of things occurred.
Yesterday evening removed the original 2 habitation batteries but only after disconnecting the electric hook up, switching the mains fuse off, switching 12v off on the control panel and switching the battery off switch on the Elektroblock, so no power to the habitation part of the vehicle.
Removed the hab batteries and decided to check if the was some form of residual voltage across the + and - battery clamps. To my surprise there was 6.3v.
As everything disconnected wasn't worried although it kept nagging at me, but we have a lot to do at the moment so got on with other things.
This afternoon went back to the job of drilling holes in the sub-floor battery box ready to take the wet batteries breather tubes. Decided to check the voltage again at the disconnected hab battery clamps and now have 9.1v, then it clicked, the starter battery is still connected to the vehicle section and although no expert thought that unless charging there is no connection between the two types of battery. Afterthought : that's not strictly true, at the rear of the EBL101 the negative leads from both the starter and hab batteries connect into the same terminal, the positives into separate ones.
Removed the 50A and 2 A fuses in the engine compartment protecting the EBL from the starter battery and voltage fell to nil at the hab battery terminals, so although nothing was on at all apart from Sprinter dash instruments in the background, voltage was transferring (although not full battery voltage of 12.8v that I later measured) to the disconnected battery terminals of the hab batteries.
How can that happen? I'm a bit bothered that there is either an Elektroblock fault and/or there is a permanent drain on the starter battery. The starter battery has been charged by the EBL up until a little over 24 hours ago, I expected that this new powerful battery would have read slightly higher than 12.8v after such a short time.
3 weeks ago the original starter battery failed dramatically over a few days, the current battery has been fitted for around 10 days.
The conundrum.
The 2 fuses just before the hab batteries are sat in a double housing, again 50A and 2A - photo 1.
The grey 2A fuse is sat in some form of adapter/extension - photo 2
It isn't an adapter at all but a second 2A fuse - photo 3
The see through cap for the lower fuse/adapter (between the upper and lower grey fuse) was found at the bottom of the battery box, someone had mistakenly fitted a second fuse - photo 2 - into the top of the first lower fuse. Both fuses were intact but how could that happen?
I guess apart from adding a little resistance by having a second fuse no harm was done.
Thank you
The conundrum.
Thank you
