Hymer door hinge
Discussion in 'Tech/Mech General' started by Redjumpa, Aug 17, 2010.
  1. Redjumpa
    Redjumpa Funster
    Oct 29, 2008
    144
    34
    North Lincolnshire
  2. wivvy's dad
    wivvy's dad Read Only Funster
    Jun 22, 2010
    3,218
    1,807
    48.066895,12.862673
    Plus Gas penetrating fluid in the first instance to un-seize it.
    Then ACF50 to lubricate initially, followed by grease or engine oil applied regularly.
  3. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    and if that does not work build a Plasticine dam around it and fill with vinegar leave for 24 hourse then rince and oil well.
  4. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,919
    1,944
    Warwickshire
    Not sure if yours is the same as more modern Hymer hinges, but if so, they should not be treated with normal compounds or freeing agents. The hinge runs on a nylon (or similar) bush and penetrating oils can cause this to swell, making the problem worse. The solution is to dismantle the hinge and lubricate it with a grease that is acid, solvent and resin free.
    Philip
  5. wivvy's dad
    Jun 22, 2010
    3,218
    1,807
    48.066895,12.862673
    Surely if it was running a nylon bush, it wouldn't have seized in the first place.
    Unless.................................................................it was treated with penetrating oil, which would have made the bush swell.
    WD40 can sometimes be your enemy.
  6. nomadic
    nomadic Funster
    Sep 27, 2007
    682
    182
    Shropshire based
    You may be lucky at Hymer parts at Preston, sorry I have'nt got there number handy just now, but they have produced a few spares, replacements for us and at reasonable prices.
    You will need to quote the details on your converters plate, on the outside of your unit, to enable them to identify your particular model. Type, serial number, build number etc.
    Hope this helps
    Nomadic
  7. Redjumpa
    Redjumpa Funster
    Oct 29, 2008
    144
    34
    North Lincolnshire
    Thanks for the tip, I managed to get the hinge off and soak it in vinegar.
    Followed by a bit of oil, grease and TLC it's as good as new.
    Only problem now is........... i've nothing to put on my chips!
