hymer , does anyone adapt a barbaque gas point ? (1 Viewer)
barwik
32
61
Barnoldswick
dont own one - yet !
newbie
Hi , We looked at various motorhomes , found one which nearly fitted our layout but not quite - it did have however a nice gas bbq point on the drivers side .
Now - we bought a B544 hymer which has a great layout but has gas bottles on the pass side - My question is - is it possible to fit an adapter to the gas pipes to then plumb in a bbq point on the drivers side as that's the side my awning is fitted ?
Not a big issue but looking forward to summer already :)
regards john
bigtwin
5,240
9,941
Derby
Concorde
Since 2006
If your fridge is on the drivers side there'll be a gas pipe there.
Ian
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
I'm sure you could (put a gas point on the other side) but why not remove a cylinder and then you could BBQ anywhere?
Minxy
32,645
66,521
E Yorks
Carthago Compactline
It is possible to put a pipe direct from the gas locker on the passenger side and run it through to the drivers side (assuming it's a RHD) but that would be quite involved, an alternative would be to tap into existing gas pipework running on the drivers side with a manifold/isolation tap, as other gas appliances have. With both scenarios it is possibly best left to a qualified LPG fitter to do it as it wouldn't be straightforward.
Minxy
32,645
66,521
E Yorks
I'm confused ... I've just been looking at photos of the B544 and they all appear to have the gas locker on the driver side (RHD) ...????
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
regards john
There's gas in the bottom of the wardrobe feeding the heating - an easy tap-off from there.
794
826
Near Truro, Cornwall
I agree with the previous comments. Here is a picture of our B544. Would be interested to see a picture of the one being described in the post though. Gary
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Yes is the simple answer to your question, the only caveat is it should be done in a professional manner using copper pipe and fittings from gas takeoff point (making sure at least one isolation valve is Incorporated), through to the rear of BBQ point itself
No Orange rubber piping anywhere in the system (other than externally from BBQ point to BBQ itself of course)
LPG rubber pipe has a lifespan of about 5 years and inspected at every use, therefor not suitable for permanent or semi permanent gas installations.
Proper gas leak testing should be carried out after install (Soap and water is not an approved method).
Geo
Lenny HB
53,410
149,879
On the coast in West Sussex
Hymer B678 DL
View attachment 137612 I agree with the previous comments. Here is a picture of our B544. Would be interested to see a picture of the one being described in the post though. Gary
That photo shows the gas locker and awning on the RHS like Mel & myself suspected, the opposite to what you said.
Minxy
32,645
66,521
E Yorks
The opposite of what the OP said, not 'Hymer B544' (you're confusing the ID and vehicle being talked about.).
Badknee
7,407
412,580
notloB
Vantage Neo
Living the dream.
We used plastic coveted copper pipe to cross from one side to the other as supplied by Gasit, a very easy job by a qualified person.
Go Humberto!
526
2,503
Hampshire
Hymer B544 A-Class
Our B544 is RHD with both doors on the right. Hence the bottles are on the left (next to passenger).
In out case the gas point is under the cooker hob. Just take the kitchen drawers out and the gas pipes are easily accessible.
It's clear that the B544 comes in a variety of body types.
794
826
Good point, which is why a picture of the B544 in question would be helpful, though only to satisfy my curiosity, the question was about fitting a gas BBQ point.
WSandME
368
453
Wigan-ish
Hymer B660 Bestline
SInce 2006
When I fitted a refillable underslung tank on our previous Hymer (1999 Starline 640) the only available space was on the UK nearside, and gas locker and associated regulator and plumbing on O/s. It was almost trivial to route a copper pipe from the new tank to the existing regulator. The only problem I had was in bending the pipe without kinking it - I didn't have a bender, and I'm almost sure I wouldn't have been able to use one in the tight confines. Plan the route, then plan which bends to make in which order.
The refillable tank and fittings I bought also included a gas-leak squirty bottle, and that helped.
Lenny HB
53,410
149,879
Hymer B678 DL
Interesting never seen a Hymer built like that before.
barwik
barwik
32
61
Barnoldswick
newbie
Hi .
Go humberto - that's exactly the type of thing I'm after and that's exactly the layout of our van - I never thought of the cooker point to tap into ... so simple !!
But that's why it was worth asking so thanks everyone very helpful
:xThumb:
