Hymer CL construction (1 Viewer)
Jan 31, 2016
1,900
3,374
Alness, Cromarty Firth
Hymer B544 (2012)
newbie
I'm a bit confused with my 552CL (Ford Chassis). It has a built in TV and there are various cables (triple cable is red, black and yellow) for sound etc in the cabinet which disappear through the wardrobe under the bed then into the floor, I've since found them in the cab part going up into the dash area.
Is the floor insulated ?? and/or in two parts as I cannot see how these cables get from the wardrobe to the cab, they don't appear under the vehicle floor (outside). When I've connected these cables to the TV nothing seems to happen so not sure what they are for.
Any ideas anyone ?
Lenny HB
53,337
149,591
On the coast in West Sussex
Hymer B678 DL
Black and red are left and right audio yellow video to connect the TV to your head unit (cab stereo). The audio will be a feed from the TV so you get good quality audio via head unit and the video will be a feed from the head unit so when you play DVD's you view them on the TV screen.
May 8, 2016
1,685
80,599
silver coast, portugal
C Class: Low profile
Boatie for 20 years
I am not familiar with the Hymer technical side of things, but if you have to use your cab audio head unit, then presumably your cab battery will be used in the process. Just be aware that if this is the case, this could mean an additional drain on your starter battery.
Lenny HB
53,337
149,591
Hymer B678 DL
Not if its wired to the hab battery.
