Hymer B594 1996 - waste / fresh water systems advice
Discussion in 'Motorhome Chat' started by Triple7, Apr 10, 2016.
  1. Triple7
    Triple7 Funster
    Sep 24, 2015
    225
    123
    Devon
    I've now been on my travels for nearly a month and I'm currently lurking in the Lisbon area. I've tried visiting Sintra a few times but if there is a less "motorhome friendly " place on the planet I'd be surprised. Sintra is stunning though so I may return. Lol
    So far everything has gone very smoothly and I continue to be delighted with the Hymer. I do have a few minor issues with water management following my initial issue with the boiler trip switch(thanks again to those what sorted me out!)
    I don't think my gauges work properly or if they do I've no idea what they are telling me.
    My first question is about the waste water drain. Mine flows very slowly (about the speed of a slow tap) and takes a few hours to empty the tank (although I've no idea how full it is in the first place) Is this normal?
    This morning I decided to unscrew the large circular hatch under the tank expecting 20 years of "crud" to slosh out but it was totally dry with just a circular polystyrene insert. What lies above that I couldn't see. What if anything should I be doing with this hatch?
    I also have an issue with the fresh water. Water appears in the shower tray and I'm not sure from where or why. My guess is the tank has a leak when it's fairly full but I'm not certain. I don't think the water is coming from the taps but it's possible it might be coming in from the outside shower located in the toilet cassette hatch.
    If any of this jogs the memory of anyone with Hymer plumbing experienes I'd be grateful for any insights.
    Thanks in advance.
  2. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,863
    1,914
    Warwickshire
    Waste tank
    Above the polystyrene disc (insulation) is a screw-in plug which is probably like the one on your fresh water tank. Unscrew this and be prepared for a torrent. I suspect the inside of your tank is coated in crud and the waste gate valve also. Get a hose up into the tank and give it a good flushing out. It's also worth cleaning the rods of the tank level sensor while you have access. This is a four-rod system: the same as fitted in the fresh tank. the rods get coated in muck and this can stop the gauge working. I cleaned the rods on mine using washing up liquid and a sponge scourer pad. Be prepared to use something like Cif if necessary. When reassembling, ensure you seat the neoprene washer correctly around the tank plug. Mine leaked and I ended up putting a bit of bathroom silicone sealant around it for good measure. It's not that difficult to twist and break the seal next time you clean it out. I have done this major cleaning project every two or three years.
    You may still need to flush the system with cleaner once everything is back together. I make a habit of putting a good dose of bio washing liquid down the sink waste every few days when we are away. Then wait until we have drive with a decent waste water load to ensure agitation before emptying. When we get home and I empty the waste tank for lay-up (even a few weeks) I use the Hymer-supplied flexi-waste hose to connect to our drain and after the tank is empty, I lift the said hose in the air and put quite a lot of fresh water 'up the spout' with a garde hose before once again letting the tank drain to waste.
    Fresh water in the shower tray
    Not sure about this one. Can you describe the layout of your shower room? For example: how is the shower mixer fitted - is there a curved trunking hiding the supply pipes; does yours have a swing-wall shower?
    • Like Like x 1
    • Useful Useful x 1
  3. Gordon1808
    Gordon1808 Funster
    Feb 21, 2016
    25
    44
    Tonbridge
    I did read somewhere, when the waste water tank is full then the water backs up the pipe work to the lowest point. Which would be the shower tray. This might or might not be the reason for water in your tray.
    • Like Like x 2
  4. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,863
    1,914
    Warwickshire
    That's true - if the waste tank is full, any further discharge into it will cause water to come up through the shower waste traps.
    • Like Like x 1
  5. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,078
    1,210
    Dronfield - Derbyshire
    Is it worth trying to back flushing through the outlet pipe with a water hose?
    • Like Like x 1
  6. Triple7
    Triple7 Funster
    Sep 24, 2015
    225
    123
    Devon
    Many thanks for the info.JeanLuc. It sounds like a very messy job to clean the tank. Is it a case of being on the flat of your back right underneath or are there any clever tricks?
    On further investigation I think the source might be in the cassette hatch. It is very wet in there but it's definitely fresh water. All the pipework connections are sound but there might be a drip coming from a plastic moulding "hole" (there are actually two, one in picture 3 and one at the back) Are these some sort of drain or overflow? From where?
    Hopefully you can also see two other pics of the bathroom and another pic of the hatch.
  7. Triple7
    Triple7 Funster
    Sep 24, 2015
    225
    123
    Devon
    Luckily it's definitely fresh
  8. Triple7
    Triple7 Funster
    Sep 24, 2015
    225
    123
    Devon
    I tried that and it helped a bit but eventually there was too much pressure
  9. Triple7
    Triple7 Funster
    Sep 24, 2015
    225
    123
    Devon
    Ive now flushed out the tank. There was very little crud in there so I'm guessing it's the waste exit which is the problem. Is there a value? When I back flush the pipe it presurises after a few seconds. I will fill the tank and try JeanLucs tip using washing liquid. If that fails I think I will just put up with it unless there are any other suggestions.
    The fresh water leak is a very slow one. I suspect it's something in the cassette hatch. Possibly the shower so I will just keep an eye on it and see what develops.
    Thanks guys for your help :)
    • Like Like x 1
  10. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,545
    9,980
    having fixed several vans with this issue, I recommend unscrewing the clamp and pull off the drain off pipe. often the waste matter forms a concretion which will not dissolve with water or soap. there are 2 answers either manually scrape out or replace the pipes
  11. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,078
    1,210
    Can you take the valve of or take it apart, it sounds like the valve is blocked - not allowing water in or out
    • Like Like x 1
  12. Triple7
    Triple7 Funster
    Sep 24, 2015
    225
    123
    Devon
    Thanks for the advice. I will see if I can get decent access to the clamp
  13. scotjimland
    Jul 25, 2007
    28,934
    25,602
    if you can't get access you could try a drain cleaner.. like Mr Muscle .. or if adventurous, caustic soda
  14. Triple7
    Triple7 Funster
    Sep 24, 2015
    225
    123
    Devon
    That's what I think the problem is. Too much of a job for me while I'm on the road unfortunately.
  15. Triple7
    Triple7 Funster
    Sep 24, 2015
    225
    123
    Devon
    Would that not damage seals etc?
  16. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,078
    1,210
    Or a piece of stiff fence wire up it's chuff
    • Like Like x 1
  17. scotjimland
    Jul 25, 2007
    28,934
    25,602
    nearly all domestic wastes are plastic, used as directed caustic drain cleaner won't attack plastic or rubber.. ...there are two risks..
    overheating and melting the plastic.. going cold and solidifying..
    try the stiff wire idea first ..
    • Like Like x 1
  18. Triple7
    Triple7 Funster
    Sep 24, 2015
    225
    123
    Devon
    Is that legal? ;-)
    Might give that a try.
  19. Triple7
    Triple7 Funster
    Sep 24, 2015
    225
    123
    Devon
    Thanks that's good to know..... Won't give up just yet!
    • Funny Funny x 1
  20. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,863
    1,914
    Warwickshire
    Your pictures indicate a different layout to mine so I'm not sure about the fresh leak. I think you may have got the best idea of where it is coming from.
    Regarding waste, if you are getting back-pressure when trying to flush water up the waste exit that suggests the valve is blocked. I think you need to wait until you can get at the valve and try to clear it.
    I'm not sure from your report above whether you removed the access plug at the bottom of the tank and flushed it through there. If not, then yes, it can be a messy job and you have to lie on your back to do it. I park at the point where our drive turns from up to down hill so the back is angled up a bit.
