Hymer B564 Water dump issues
Discussion in 'Motorhome Chat' started by cainee, Apr 23, 2014.
  1. cainee
    cainee Read Only Funster
    Oct 21, 2012
    10
    Swansea
    I have just pulled up at a campsite and as soon as I connected the electric the water dump started. Now i have just replaced the engine battery due a dead one being in its place and I wondering if this is the case. I now cannot have the lights on due to the water pump going crazy after emptying 120 litres all over the grass outside. If anyone has any help please do. I think I need to know how to reset the boiler from dumping the water (if this is the case).
    Thanks.
  2. Mr Colpot
    Mr Colpot Funster
    Apr 29, 2009
    696
    250
    West Sussex
    If you look in the Cupboard where the boiler is there should be a red valve which may have dropped down due to the temperature. If you pull it up it should stay up. I seem to remember on our 564 I sometimes had to turn the blown air heating on first to warm the van if it is still too cold. The water pump should have an independent switch on the control panel so you can turn it off and still run the electrics.
    Hoping you got it sorted last night though!!
  3. cainee
    Oct 21, 2012
    10
    Swansea
    Water pump dumped
    The water pump just emptied 120l of water out and I couldn't stop it. I have now removed the fuse so that we can now use the electrics without it burning the motor out.
    I am sure there is someway of resetting the electrics and so stopping the water pump just dumping all the water out.
  4. Detnor
    Detnor Funster
    May 12, 2011
    537
    471
    Is the water coming out from a pipe under the boiler or under the water tank? As mr colpot says the truma water heater has a dump valve that will empty everything if open. From memory a black valve with red handle. Newer models have a push button then when it stays in you can turn the valve next to it.
  5. cainee
    Oct 21, 2012
    10
    Swansea
    Came straight out from a pipe under the boiler, but was being emptied by the water pump, continuously.
  6. Microchip
    Microchip Funster
    Apr 8, 2012
    129
    123
    Hampshire
    Seems like 2 faults ...however, if the water is coming out of a white pipe it will be the "t" connector on top of the boiler, there is a small ball inside which is the release valve, the ball will be missing.
    For the pump always being on either there is a faulty tap micro switch, or the wires that connect to the switch is shorted:Doh:
    Keith
  7. cainee
    Oct 21, 2012
    10
    Swansea
    It seems that the water was coming out of the black down pipe last night and not the red one that also hangs down below the boiler.
  8. bjandlin
    bjandlin Funster
    Feb 29, 2012
    175
    98
    Reading & Surgeres France.
    boiler dumping water
    Good morning .
    As some one has already said your problem is most likely to be the dump valve. It's designed to open & drain the boiler once outside temperature nears freezing, to prevent damage to the boiler.
    You should find the valve almost alongside the boiler, it is on my 584.
    It's black with pipes running to it & a red knob on the top. As you say you've changed a battery that may well have caused the problem. The valve opens when the 12 volt is turned off.
    Make sure you have the 12 volt on & pull the red knob upwards, you should feel it click & lock in the up position. That should then have solved the problem.
    Barrie
  9. cainee
    Oct 21, 2012
    10
    Swansea
    Thanks all for the help. I took the fuse out reset the transformer and filled it up with water again. It all worked perfectly.
  10. cainee
    Oct 21, 2012
    10
    Swansea
