Hymer B564 basin tap
Discussion in 'Hymer' started by Periscope, Jul 15, 2016.
  1. Periscope
    Periscope Funster
    Jul 14, 2016
    31
    3
    France
    How do I get the old one off?????????
    Doesn't seem to be enough room to get at it and the easy solution seemed to be to take the basin off. That is, apart from the waste pipe and a seeming hidden fixing at the left hand end?
  2. Flamenca
    Flamenca Funster Life Member
    Jun 21, 2013
    763
    460
    Cornwall/France/Spain
    Do you have a combined hob/basin assembly? If you do it is necessary to remove the dowells at the ends of the timber rail at the front. If that is the case with yours I have hand written instructions produced by the previous owner of mine which I can scan.
  3. Wagoneer
    Wagoneer Funster
    Jul 6, 2016
    175
    86
    Sussex
    Can I ask why you want to remove the complete tap ?
    You can sometimes undertake repairs whilst insitu.
  4. Periscope
    Periscope Funster
    Jul 14, 2016
    31
    3
    France
    Ah, sorry, not the sink but the basin (bathroom).
    As to why, the previous owner had bought replacement taps for both kitchen and bathroom. He changed the kitchen one (which is comparatively easy) but cried off the bathroom one, claiming lack of time.
    I hadn't understood why until we found a puddle of water on the floor. It seems to be the base of the tap that is springing the wet stuff, so no obvious fix.
  5. Wagoneer
    Wagoneer Funster
    Jul 6, 2016
    175
    86
    Sussex
    Can you get your hand to the underside of the tap ? If so, I've previously used "non-slip rubber matting" to wrap around the plastic hexagonal nut to undo by hand. You should also be able to rotate the upper part of the tap to help with the removal process. Because of limited space it's normally very difficult to use a spanner or adjustable grips to remove the hexagonal nut.
    If it's a Reich tap you can easily remove the tails (blue & red) which are attached to the incoming flexible pipe work. There is a plastic pin between the two tails. This just needs to be removed and the tails can be pulled out. Check your new tap to see if this is the case. Your new tap should have barbed tails (some are smooth).
    Failing all that, just hire the services of a contortionist, haha !!!
  6. autorouter
    autorouter Funster
    Apr 27, 2016
    123
    48
    Manchester
    Leaks from pipes and joints, both taps cracked... classic frost damage.
  7. Periscope
    Periscope Funster
    Jul 14, 2016
    31
    3
    France
    @autorouter. That makes an abundant amount of sense. I think may have to study the rest of the water system more closely.
  8. bjandlin
    bjandlin Funster
    Feb 29, 2012
    175
    98
    Reading & Surgeres France.
    Hello, what year & layout do you have ? 2005 ish may be able to help, just changed one on my 584.
    Barrie.
  9. Wagoneer
    Wagoneer Funster
    Jul 6, 2016
    175
    86
    Sussex
    The B564 has the bathroom area right across the rear of the van (quite a rare beast). Well, this was the layout up to 2006.
  10. Periscope
    Periscope Funster
    Jul 14, 2016
    31
    3
    France
    Job done and if anyone needs to know how and are prepared to grovel......
    ....and trust me, it is a sod!!!!!
  11. Wagoneer
    Wagoneer Funster
    Jul 6, 2016
    175
    86
    Sussex
    Yes, it would be appreciated if you could post a brief description of the procedure you used. It may help others to tackle the job and avoid any of the potential pitfalls.
    I'm recovering from an awkward job undertaken on the camper last week. I've still got a stiff neck which is quite painful at times. Hope you don't suffer any after effects - it's quite easy to strain muscles you thought you never had !!!
  12. Periscope
    Periscope Funster
    Jul 14, 2016
    31
    3
    France
    Doesn't it hurt?????? One needs to be an ambidextrous midget to work comfortably.
    OK, procedure was thus.....
    Drain tank. If you then the water just keeps flowing on the cold side. Don't know why but it did so be warned!!!!! Pump wasn't kicking in but...........
    Turn off power.
    Disconnect tails. Remove retaining nuts before they slide down pipes out of reach!!!!!
    Disconnect cables.
    Remove centre screw from waste outlet.
    Remove caps from screws and unscrew same that hold back panel and basin to wall.
    This then allows you to gently lift/flex basin up at front and gives you enough room to get a pair of grips onto brass nut.
    Remove spout from tap (small screw on underside)
    Hold grips onto brass nut and turn tap in anticlockwise direction until you can remove tap. This sounds easy but brass on plastic thread is bloody stiff. Attempts at lubing made no difference. Maybe I should have tried different lubes. Wd40 and grease made no difference at all.
    Fix new spade connectors onto electrical tails.
    Introduce tap into hole.
    Slide underside washer over tails and then threaded part of tap. This has to be done from underneath and there is very little space for your hand.
    Prop up front edge of basin so you can see new brass nut when screwing it on.
    Thread new brass nut over electrical tails.
    Offer it up to threaded part of tap and then swear profusely when it won't catch. At all costs keep hold of nut and do not let it drop down pipe well!!!!!
    You will know when thread has caught right because it is just as stiff as the one you've just removed. If you don't believe me then do a dummy run before you off tap up to hole. If you find a lube that works then let me know!
    Now comes the painful bit of laboriously turning that nut with your wrench, on your knees with head tilted at 60 degrees, for five minutes.
    Shout with triumph and scare all wildlife/small children within thirty yards.
    Connect cables to appropriate coloured opposites. (For those of you with black and white televisions, that's blue to blue and brown to brown)
    Reconnect pipes to tap tails. (Long tail is cold).
    Stuff some wet stuff in tank and give her a whirl. If it works then refix screws, have a large drink and do nothing for the rest of the day.
    Next time, pay someone else to do it!!!!!
    • Useful Useful x 1
  13. Periscope
    Periscope Funster
    Jul 14, 2016
    31
    3
    France
    Actually, bathroom is on the side, in the corner. Separate shower.
