Hymer B544 shower tray removal (1 Viewer)
neil2016
24
26
Chalfont st Peter
Hymer B544
I'm a newbie
Having just bought our Hymer B544 last week this weekend has been spent starting the interior renovations. Our plan is to replace the upholstery and to change the configuration back to the original 4/5 berth from the 3 ber
th
that it currently is. Part of the project also involves replacing the shower tray as unfortunately this is cracked. So yesterday was spent removing the tray. There is an excellent video on YouTube that shows the procedure and without which I would have thought twice about attempting. The video can be found here.
And while the Hymer model is an S555 the shower looks to be the same as the B544.
Taking the tray out went incredibly smoothly until i had to undo one screw that held the Thetford toilet in place. It took almost as long to remove this as it did the rest of the bathroom units! Once out however, the excellent news was that there was no water damage under the tray. Also the tray came out easily without further cracks, which should hopefully help when it comes to making the mould for the replacement tray. Below are a couple of photos showing the bathroom after the removal of the tray along with a photo of the tray itself and the crack.
Aug 6, 2013
11,949
16,551
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Having just bought our Hymer B544 last week this weekend has been spent starting the interior renovations. Our plan is to replace the upholstery and to change the configuration back to the original 4/5 berth from the 3 berView attachment 154470 thView attachment 154470 that it currently is. Part of the project also involves replacing the shower tray as unfortunately this is cracked. So yesterday was spent removing the tray. There is an excellent video on YouTube that shows the procedure and without which I would have thought twice about attempting. The video can be found here.
You're wearing my slippers :D2. Nice work by the way.
TheBig1
17,575
42,958
there are a few firms that have already made moulds and produce grp replacement trays. or have an aluminium tray folded and welded would be my advice
Moodybrook
802
651
Wet and cold place outside of M25
4 wheels and a pointy end
still in nappies
the shower tray
Well done for having ago. I did mine and although it isn't a Hymer It was just the same load of cheap sxxt that you have. I put a domestic one in and reclad the whole washroom. Once you throw the rubbish away and clear the decks it is relatively straight forward. I worried about it before I started but now when on the throne I survey my own handiwork with some satisfaction, yes, and the washroom :D
Charlie68
Bridgend, UK
B544 Hymer Clasic
Since 2018
Hi Neil2016
I noticed on your video that there were 2 hot water pipes between the tap in the bathroom and the kitchen and only one between the bathroom tap and boiler. Does this mean that the hot water supply in your van goes into the kitchen first and then back to the bathroom tap?
Brilliant video by the way.
