Hymer B535 Tyre size
Discussion in 'Hymer' started by Donk, Apr 3, 2010.
  1. Donk
    Donk Read Only Funster
    Nov 23, 2009
    3
    Bracknell
    Hi All I have a 1968 Hymer B543 based on a Fiat Ducato and need some help in getting new tyres. The size on the tyres is 185R14C. I have tried putting this size when using on line tyre suppliers and they say no size . Is there a compatable size I could use can anyone help me with this problem. Very many thanks in advance Dave
  2. MAUBRI
    MAUBRI Funster
    Aug 9, 2008
    195
    4
    Lanner - Cornwall
    I think your find you have misread the tyre, there should be another number on the lines of 185/55R14C. etc
    But I expect Brian Evans will be along soon to put you right
    Brian
  3. Donk
    Nov 23, 2009
    3
    Bracknell
    Hymer tyre size
    Hi thanks for your reply . I know what you mean but on these tyres the only size on them is 185R14C hence my problem
  4. MIN663
    MIN663 Read Only Funster
    Sep 19, 2009
    98
    Cornwall
    Hi Donk,
    Dont know if this will help but just been and checked tyres on my 1989 B534 and its fitted with 195/75R16C
    Cheers Min:thumb:
  5. jaygee
    jaygee Funster
    Mar 21, 2009
    1,168
    721
    Harwich, Essex
    185R14C is a legitimate tyre size it's a light commercial tyre i.e. van or 4wd and is readily avaliable from most tyre suppliers.
  6. lebesset
    lebesset Read Only Funster
    May 31, 2009
    760
    185 x 14 C is a tyre that dates from 30-40 years ago ...they are not available any more in my neck of the woods
    having said that I happened to know that hankook [ good quality tyre ] were making them not long ago , so you could try a hankook agent if all else fails
    if after that you really can't get any of this size , if is probable that a more modern tyre is available in a size to do the job ; if you post
    the axle weights
    the rim dimensions [ if you look on the rim it will be marked as something like ....5 1/2 J 14 ]
    I will work out if there is something available
  7. jaygee
    jaygee Funster
    Mar 21, 2009
    1,168
    721
    Harwich, Essex
