hymer B534 electrics
Discussion in 'Tech/Mech General' started by Queenie, May 16, 2014.
  1. Queenie
    Queenie Read Only Funster
    Jan 25, 2013
    51
    7
    Cornwall, United Kingdom
    is there anyone around Newquay, Cornwall can help me with my Hymer electrics. Im on the road hooked up and I've got no power on 12v or 240v lights, fridge and water pump. One 240v plug works, and thats all. i don't know how to check fuses in the habitation box. Im a dumb blonde when it comes to electrics?:RollEyes:
  2. mikekaren2
    mikekaren2 Funster
    Dec 5, 2013
    314
    246
    Somerset
    Sorry, to far away to help, but I notice your profile states "years motorhoming" 2000!You must have picked up some lecy knowledge in 2000 years!
    What's your secret for a long life ;-)
    • Like it Like it x 1
  3. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,937
    1,957
    Warwickshire
    I am assuming it's a new(ish) Hymer (late 90s onwards).
    There are no 230V internal lights so far as I'm aware - they are all 12V.
    So if the entire 12V circuitry is out, have you checked that the main switch on the Electrobloc charger is switched on? This is a blue-cased unit with a white face containing lots of connectors and fuses. It is often located under a front seat or in the side wooden cabinet next to the front right-hand seat. Sometimes it is in a locker. If this switch is off, the step and door light will still work, but all other 12V circuits are disabled.
    If it's not that, I'm a bit stumped and would suspect a failure in one of the 230V cable runs - obviously not the one to the socket that is working. Unlikely though I would have thought.
  4. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    is it a new to you van, one socket is working so power is getting to the van, other than that it looks like a switching problem, do you have a manual, how old is the van, is there an RCD under the seat or in a cupboard. Is it a new problem how long have you had the van. There are funsters round and about Cornshire who could help a maiden in Distress, put the kettle on and they will turn up in droves.:Rofl1::Rofl1::Rofl1:
    Is it possible that the one socket that is working is wired to an inverter?
  5. HymerB544
    HymerB544 Funster
    Apr 25, 2012
    728
    734
    Near Truro, Cornwall
    Hymer electrics
    Hi Queenie,
    Sue and I live about 15 miles from you just outside Truro so I could pop across tomorrow if that's any help, but not tonight I'm afraid. Our van is a Hymer A class too, 2006, and from your description it sounds like a fuse or several fuses, problem. The fuse box in ours sits in the side locker next to the driver under a sliding cover. If you look at each fuse in turn, you should be able to spot which ones have blown. It would help if you had the Hymer manual which shows in diagram which fuses cover which circuits. We have had one recurring fuse problem with our van; whenever we switch on the vertical strip light by the door on the edge of the wardrobe, it blows one of the 10 amp fuses. So we have tape over the light switch. It can't be a mains supply problem if you have one 240v socket working, so must be a fuse I reckon. :Smile:
  6. Queenie
    Jan 25, 2013
    51
    7
    :Doh: i did say i was a dumb blonde:Laughing:
  7. Queenie
    Jan 25, 2013
    51
    7
    Thanks Guys, The van is down at the Lizzard till Sunday, will check on Monday when van comes back, my friends are borrowing it at the moment. :thumb:
  8. Queenie
    Jan 25, 2013
    51
    7
    Well i let my friends borrow the van for the weekend, and they didn't know you had to put the 12v switch on to get the vans lights on, so everything is ok, thanks for all your help anyway. Im so relieved it wasn't a major problem.
