Hymer 660S Wheel Base
Discussion in 'Tech/Mech General' started by enery8, Jan 5, 2013.
  1. enery8
    enery8 Funster
    Oct 11, 2012
    536
    578
    Morning Funsters, Can anyone tell me the wheel base of a Hymer 660S from around the mid 80s. Also, if possible the length of the overhang behind the back axle.
    the reason for the questions is that I hope to buy one of these iconic motorhomes but have to consider my 1 in 7 drive and back garden where it will live.
    thanks in advance
    Bill (enery8)
  2. JJ
    JJ Funster
    May 1, 2008
    15,015
    27,014
    Do do want me to go outside with my tape measure now [STRIKE]'enery[/STRIKE] Bill ?
    JJ :Cool:
  3. enery8
    enery8 Funster
    Oct 11, 2012
    536
    578
    Hi JJ, Not necessarily, when ever it is convenient. In fact an approx will do.
    I just need to know I can get it in the garden before I go flying off to Germany to buy one! We can't get the caravan out of the garden on the back of the car without dragging its ar5e on the flat area as the caravan goes up the ramp. This is why we had to buy a motor mover.
    Thanks for your answer.
    all the best
    [STRIKE]enery8[/STRIKE] Bill
  4. JJ
    JJ Funster
    May 1, 2008
    15,015
    27,014
    Roughly...
    Wheelbase 3.7 metres.
    Overhang 2.0 metres
    JJ :Cool:
  5. enery8
    enery8 Funster
    Oct 11, 2012
    536
    578
    Thanks JJ, thats brilliant! now I can start measuring :BigGrin:
    cheers, Bill
  6. Terence
    Terence Read Only Funster
    Jun 27, 2011
    16
    7
    York
    660 over hang
    Hi Enery8,
    A point to consider is if the vehicle you are looking at has a towing bracket they are low on a S660. You can remove it of course if you do not need it.
    I removed mine and it weighed 56 Kilos. Great vehicle had mine over ten years and it has done 150,000 miles and still going strong
    Terence
  7. enery8
    enery8 Funster
    Oct 11, 2012
    536
    578
    Hi Terence, Thanks for your input and the info about the towbar. I reckon we will need to use a towbar at times so will have to find a way to overcome that.
    Does your 660s have air suspension? if so can you control the height? On my Range Rover there are 3 height settings that are user controllable. Loading, Normal and Wading. Wading is the highest. That little bit of extra height would make all the difference getting into our garden. Might have to have the drop kerb redone to lower the overall gradient of the driveway :Doh:
    Thanks again
    Bill
  8. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    you could always fit some industrial rollers under the towbar to stop it dragging.
    the other option is get some short planks to get the height of the rear of the van up that once onto the second plank the front one gets put behind and so on until its fully on the drive.
  9. veevee
    veevee Funster
    Jul 4, 2010
    984
    551
    Essex / central France
    I'd be tempted to alter the drive a little if possible, plus fit a replaceable skid plate under the tow bar to give more clearance then rollers.
  10. enery8
    enery8 Funster
    Oct 11, 2012
    536
    578
    Morning Jamie,
    Thanks for the idea, I think the skid plate might work (if necessary) We are already working on ideas for altering the drive, it needs repair in any case. I reckon I will have to have it skimmed and the area where the ramp meets the flat area along side the house filled in with fresh concrete.
  11. Terence
    Jun 27, 2011
    16
    7
    York
    S660 tow brackets
    Good morning Enery8
    I know at least half a dozen people with S600s, to my knowledge no one has fitted air suspension mainly because the vehicle has a gross weight of 4700 kilos and unless they have a problem such as yours it would be a non starter in my opinion. From memory the tow bar is fitted to the chassis just behind the rear springs and has a very long single bar extending to the towing ball. Therefore I suggest there must be scope for fitting some kind of, 'Quick fit attachment' modification to the extention bar to reduce the length when reversing up the slope.
    Terence
  12. Mel
    Mel Funster
    Oct 6, 2012
    2,134
    2,155
    De Haan Belgium
    Sounds like it may be beter to buy a new house on the flat:BigGrin:
    Hope you find what you want
    I think the old Hymer is now an icon.
    Mel
  13. enery8
    enery8 Funster
    Oct 11, 2012
    536
    578
    That is very useful info Terence. I reckon I could work with that and make it a detachable towball. thank you for that. We are thinking that we will reduce to slope of the drive by filling in the bottom where it meets the flat part so that it levels out more gently. So maybe won't 'need' air sus but if it already has it ..........:thumb:
    Bill
  14. enery8
    enery8 Funster
    Oct 11, 2012
    536
    578
    Hi Mel, We live in a sheltered bungalow and really don't want to move anyway, even if we had the choice. The driveway is the only negative:Smile:
    If we hadn't lost our own place in the 80s due to illness and the sky high interest rates we would likely be living in France by now :cry:
    However, we are happy where we are and will sort the problem and travel to France when we get our MH.
    Interesting that you were a Transport Manager, I worked in Road Transport all my working life from van boy though the ranks to Distribution Manager including teaching CPCs on secondment.
    Thanks for your good wishes.
    Bill
