Hydraulic Thrust Bearing Unit Inside The Gearbox Bell housing
Discussion in 'Tech/Mech General' started by Hydrocell, Jul 24, 2014.
  1. Hydrocell
    Hydrocell Funster
    Jun 22, 2012
    176
    112
    Ebbw Vale Gwent
    Good afternoon everyone,
    Has anyone experienced any problems with the clutch thrust bearing on a 130 multijet with the six speed gearbox on the Fiat X250.
    Regards
    Ray
  2. MikeD
    MikeD Funster
    Dec 21, 2011
    2,155
    1,883
    London
    Nope - 15k miles from new, mostly motorway
  3. Hydrocell
    Hydrocell Funster
    Jun 22, 2012
    176
    112
    Ebbw Vale Gwent
    Mine disintegrated at 24,000 mile stopped at the traffic lights in Olivia in Spain pulled of went to change in too second gear and found clutch pedal flat to the floor.
    Managed to get to Tavernes where we parked right next to the beach.
    • Like it Like it x 1
  4. MikeD
    MikeD Funster
    Dec 21, 2011
    2,155
    1,883
    London
    Oh Crap :(:(
  5. andyman
    andyman Funster
    Sep 23, 2007
    1,154
    509
    Leicestershire
    I had a problem with the pedal sticking down, then the clutch would not clear.
    Changed the thrust bearing the pipe and the extension pipe / bleed nipple.
  6. Hydrocell
    Hydrocell Funster
    Jun 22, 2012
    176
    112
    Ebbw Vale Gwent
    Good morning all thank all for your replies.
    It looks like at the moment that it seems to be just a bit of bad luck on my part, after looking on lots on forums to find how many others have suffered from similar problems.
    Just one other thing, the leak from the bearing bid not contaminate the clutch plate, so the only part to be replaced was the bearing, cost £85 which comes complete with extinction pipe and bleed nipple, the down side is the gearbox has to be removed to replace the part.
    Regards
    Ray
  7. WillH
    WillH Funster
    Feb 9, 2008
    1,745
    1,470
    SW Scotland
    We have almost 40k on the clock, new heavy duty clutch fitted by Fiat at 5k and no problems since.
  8. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    why take it all apart and not replace the clutch you might as well do that as well at the same time.
  9. Hydrocell
    Hydrocell Funster
    Jun 22, 2012
    176
    112
    Ebbw Vale Gwent
    Hi Wildman
    I understand where you’re coming, as I stated in my thread there was no contamination on the clutch plate and very little signs of any wear, so in my opinion it did not need changing.
    Believe it or not it is a very straight foreword job even in a car park so at home it would be much easier.
    The hardest thing was trying to get the part in Spain, gave up in the end and had the part flew out to me in Tavernes.
    Regards
    Ray
  10. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,101
    17,770
    YO11 2BD
    Im confused........
    Hydraulic release bearing ?
    Release bearing is a caged ball race which is actuated by a release fork, pushing the bearing onto the clutch pressure plate
    The fork is moved either hydraulically by a slave cylinder or by a cable.
    The slave cylinder may well be in the bell housing but has no resemblance to the bearing.
    I can only assume you mean the slave cylinder had failed and that comes complete with extension pipe and nipple as its inside the bell housing.
  11. Hydrocell
    Hydrocell Funster
    Jun 22, 2012
    176
    112
    Ebbw Vale Gwent
    Hi Pappajohn
    You are right it is the clutch bearing that operates the clutch, it is actually called a Hydraulic Concentric Slave Cylinder
    Regards
    Ray
