how to work out resistance of a bulb?
Discussion in 'Tech/Mech General' started by seanoo, Dec 7, 2014.
  1. seanoo
    seanoo Funster
    Nov 14, 2009
    374
    228
    normandy
    hi all, the reason i need to know is that the fan on my sog has busted . sog want £46 for a new fan and i have to post the old one to them before they will send out a new one as they only supply on an exchange basis . so i have been to a computer shop and bought a few old 12v 80mm cooling fans. the first one i installed only lasted 2 days and then burnt out so i replaced with a 2nd which burnt out again after 1 day. the last fan which is quite a bit beefier although the same size runs so fast it sounds like a mini jet engine so i have put a 12v 5 watt bulb in the positive lead and this has slowed it down by about half and it works well . its a bank holiday here in spain so i can't get to a shop to get a resistor to replace the bulb but i need to know which resistor to get or is there a better way to lower the fan speed maybe with a pot? all the best sean.
  2. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,315
    8,026
    West Norfolk
    5watts divided by by 12volts = 0.416 amps.
    Therefore, 12 volts divided by 0.416 = 28.84 ohms.
    A 30 ohm resistor should do it!
    • Like it Like it x 2
  3. seanoo
    seanoo Funster
    Nov 14, 2009
    374
    228
    normandy
    lightning fast reply jon cheers! i will get a few of them on tuesday and replace the bulb.
  4. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,315
    8,026
    West Norfolk
    Of course you could fit a 24 volt fan and this will run much more slowly!
    • Like it Like it x 1
  5. seanoo
    seanoo Funster
    Nov 14, 2009
    374
    228
    normandy
    i think i'll stick with the 12v fan i've got as it seems good quality. what i'll probably do is get 3 x 10 ohm resistors and solder them in series to keep any heat down and shrink tube them.
  6. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,315
    8,026
    West Norfolk
    Three 30 ohm resistors in series will make them 90 ohms!
    It you meant parallel, that will make them 3 ohms!
  7. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,315
    8,026
    West Norfolk
    You need a 30 ohm resistor capable of taking the current!
  8. Borderland
    Borderland Funster
    Nov 5, 2014
    450
    2,508
    Borders
    Yes, make sure you get the correct wattage rated resistor
  9. Borderland
    Borderland Funster
    Nov 5, 2014
    450
    2,508
    Borders
    That's assuming there is 12 volt across the bulb but the above calculation should be a good starting point. You could try a few different values of resistor to get the desired effect. If you have a voltage meter you can measure the voltage across the fan.
  10. Terry
    Terry Funster
    Dec 27, 2007
    10,784
    6,293
    South yorks
    Are you sure you have a 12v fan ? I only ask as quite a few comp ones are 5v -you could be sticking 12v into a 5v one making it buzz around twice the speed -Personally I don't mind my fan whirring away -at least I know it's working
    terry
  11. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,315
    8,026
    West Norfolk
    Agreed!
    Measured resistance of a bulb is always zilch!
    It only becomes resistant once the filament warms up. Therefore resistance can only be calculated based on known voltage and current values using Mr Ohm's well proven law!
  12. seanoo
    seanoo Funster
    Nov 14, 2009
    374
    228
    normandy
    hi jon, no in my post i said 3 x 10 ohm resistors. not 3 x30 ohm ones.
  13. seanoo
    seanoo Funster
    Nov 14, 2009
    374
    228
    normandy
    definately a 12v fan but just hooked up to 12 v it goes too fast and noisy to do the job.
  14. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,252
    17,924
    YO11 2BD
  15. seanoo
    seanoo Funster
    Nov 14, 2009
    374
    228
    normandy
    i will get a pack of different resistors and try those and if it fails i will just leave the bulb there! it doesnt glow very much so there isnt much heat produced.
  16. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,315
    8,026
    West Norfolk
    Sorry, will read before hitting the keyboard next time!!!!
  17. John Laidler
    John Laidler Funster
    Jan 9, 2013
    9,055
    12,410
    Plympton, Devon
    I think it would be much more fun if you used a bulb and mounted it inside the cassette. This would improve aim significantly when used at night. :)
  18. Gizmouk
    Gizmouk Funster
    Nov 6, 2013
    1,022
    1,815
    Essex
    Wouldn't it be best to start at step 1 ?
    1. Measure the voltage across the original fubar fan.
  19. seanoo
    seanoo Funster
    Nov 14, 2009
    374
    228
    normandy
    hi gizmouk , i dont need to now as i have the fan working as it should at the speed i want albeit with a bulb as a resistor. now i just need to play with a few resistors to get the same affect.
  20. Gizmouk
    Gizmouk Funster
    Nov 6, 2013
    1,022
    1,815
    Essex
    Couple of resistors as a potential divider should do the trick
