How to Use a Multi-meter to check amps (1 Viewer)
Braunston
1,408
7
Hi,
Just thought this "YouTube" demonstration on how to use a Multi-meter to check for amps, e.g. drain on your battery, may be helpful to someone
You may want to do this if your Cab Battery or Leisure Battery keeps losing its charge. as it will show you if there is something that is taking the power.
Hope it helps someone
A
aamybush
Thanks!!!
Hi Braunston,
this video from youtube is useful to me...again thanks a lot!!!
flyboy
30
4
Carlisle
I was wondering how to do that! Thanks very useful
Geo
Trader - Funster
Jul 29, 2007
11,757
14,563
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
This I think is where a little knowledge is more dangerous than non
amp test's appropriate to a multi meter's are limitedby its range, and that is quite low , if the expected results are not known :Eeek: pop goes the multi meter, and amp's burn:cry:
ever seen 30amp's go through a 10amp meter:RollEyes::RollEyes::RollEyes: Sizzling sausages springs to mind:ROFLMAO::ROFLMAO:
Geo
43,207
48,811
if you really need to check ampages then i suggest you invest in an LCD clamp type meter.....around £40 but money well spent.
just open the jaws and place around the cable to be tested.
put it around your leisure battery pos lead and it'll tell you instantly how many amps your pulling or around any individual wire and it'll give you the amps for that particular circuit .
only disadvantage is it must ONLY go around the + OR - wire....not both together.
as there is no direct contact it cant be damaged by overloading it.
mine has a range of 1 milliamp to 100 amps..both AC and DC current......enough for just about any test.
Oct 13, 2016
1,050
896
Grays - Essex - UK
Mercedes Hymer B680
Been moho’ing for a time now
pappajohn, hate to be a pain, but I'm a retired electrician (know all about tong testers) perhaps you could put the name of your tong tester up, as there are NOT many tong testers that do AC & DC, and more so DC up to 100 amps?
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
Old thread this, if you want to attract a members attention you should use this
@pappajohn
43,207
48,811
Its in the garage or caravan at the moment.
I'll dig it out tomorrow and post details and a pic or two.
Roadrunner_644
19
4
Leicester
Hymer A Class B644
Since 1990
Think it was techno that posted an amazon link to this one :-
Link Removed
I got one, and I'm very happy with it.
KeithMak
50
32
South West
none
or this one that is a multi-meter.
Example only not an endorsement of seller, have pone and regularly use it.
Do ensure you get the correct model as similar looking will not read dc. amps
43,207
48,811
Pics as promised.....but it's 80a ac/dc, not 100a as posted
Oct 13, 2016
1,050
896
Grays - Essex - UK
Mercedes Hymer B680
Pappajohn, please accept my apologies, I retired back in 2010, things have obviously moved on quite a bit since then, most of my work was testing properties, I had a few "Amprobes"(tong testers) one actually measured up to 1000 amps, but only over AC, piccies later
43,207
48,811
No apologies necessary.....but I've had that meter since 2004. :LOL:
