How to shorten satellite cable????????
Discussion in 'TV & Satellite' started by icantremember, Mar 20, 2012.
  1. icantremember
    icantremember Funster
    Sep 2, 2010
    5,209
    7,304
    Nr Watton in Norfolk
    When our Camos satellite dome was fitted all the excess cable was coiled up and strapped to the roof, now all the leaves and other crud get caught in it. So I would like to tidy it by cutting out a section to make it shorter.
    My problem is that I believe it is more than just a coax cable and includes data cables as well.
    Can anyone please advise how I could rejoin the cable to keep water out and without affecting reception.
    Brian
  2. eddievanbitz
    eddievanbitz Trader - Funster
    Oct 4, 2007
    3,602
    11,262
    Taunton Somerset
    Yes simple! As it is a poor installation fault, go back to the installer and tell them to tidy it up!
    Coiled cables on the roof! Sounds horrible.
    Eddie
    • Like Like x 2
  3. icantremember
    Sep 2, 2010
    5,209
    7,304
    Yes thanks Eddie but I'm trying to avoid a 150 mile trip so do you reckon I can shorten it?
    Brian
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,690
    17,300
    YO11 2BD
    if you do it may affect efficiency.....
    joining co-ax is easy with an inline coupler but if it does have other wires incorporated it could be a problem.
    can you pull the excess inside and coil it back up in a corner of a locker etc ?
  5. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,611
    238
    Gone RVing
    Brian, I'd call who ever installed it and have a chat, if nothing else confirm whether it's just coax, simple to sort or more complicated, and raise the issue of untidy workmanship?
    By the by, I guess you've got the van back from the rear end replacment?
    If you have, how'd it go?
  6. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,551
    3,361
    Telford, Shropshire
    While in the first instance I agree with Eddie, a shoddy job the answer is simple. As its a Camos dome you can simply shorten the coax as that is all it is, the motor drive power and signalling is done up the same wire as the satellite signal is fed down to the controller. If you need advice on how to shorten coax then I'd respectfully suggest you get someone else to do it.
    D.
    • Like Like x 1
  7. eddievanbitz
    Oct 4, 2007
    3,602
    11,262
    Taunton Somerset
    LOL I know what you mean with some of the questions asked.
    Don't forget the MK 1 Camos's and the in motion have a data cable as well as RF!
    Eddie
  8. Road Runner
    Road Runner Read Only Funster
    Jul 26, 2007
    14,196
    1,459
    Europe
    Brian if you can hang on till I am at home will nip up and do it for you:Wink::thumb:
  9. icantremember
    Sep 2, 2010
    5,209
    7,304
    Thanks John, while I'm happy to cut & join coax I'm pretty certain there are data cables involved as well so dragging it all inside is probably the right answer. Brian
    Hiya Si, I think I shall just pull it all inside as it seems the easiest solution.
    Yes thanks we got the van back from Swift last month after they had it for a couple of weeks. During which time they made a good job of the repair and also did a few other jobs and paid all expenses including hotels so we are happy bunnies. Brian
    Thank you Dave, I am quite capable of dealing with standard coax, my query is if there are separate data feeds within the cable. Brian
    Eddie, I don't know if my Camos is a Mk1 or not, according but according to the manual it is a CSA1400P. Brian
    Thank you so much John for your kind offer but I reckon you will be far too busy keeping up your Maroc suntan :Rofl1: Brian
    • Like Like x 2
  10. dave newell lvs
    Oct 31, 2008
    2,551
    3,361
    Telford, Shropshire
    Sorry Brian, I didn't mean to infer you were not capable but if you look at it from my point of view I don't know you or what your capabilities are hence my comment about if you have to ask how to shorten coax you should get someone who knows what they're doing. My apologies if it came over as rude or suggesting you were any less than competent, that was not my intention.:Wink:
    D.
  11. icantremember
    Sep 2, 2010
    5,209
    7,304
    Cheers Dave but really no apology necessary, no offence taken.........thanks for your input:thumb: Brian
  12. eddievanbitz
    Oct 4, 2007
    3,602
    11,262
    Taunton Somerset
    Simple, look on the roof if you have one wire plugged in you have a cable you can shorten. If you have more, move the excess inside and coil
    Don't thank me you can give me a beer at Peterborough :Wink:
    Eddie
    • Like Like x 1
