How to refix this to the door (1 Viewer)
Bart
3,188
1,397
Northern Ireland
Boxer L4H2 van build
Since 2016
So I hung a towel on this hanger which is inside the bathroom door on our bessacarr E560 when the towel just fell to the floor along with the hanger. It just pulled the hanger from the door which screws into the door via the small screw.
So now I am unable to reattach the hanger as the screw turns and I am unable to see the screw head as the unit seems to be 1 sealed unit . But surely there must be some way that it splits / unscrews apart to get at the screw so you can reattach it.
To me looking at it I see no obvious way to open it up like unscrewing it apart.
20160812_092025.jpg 20160812_091931.jpg 20160812_091917.jpg 20160812_091821.jpg 20160812_091805.jpg 20160812_091658.jpg
D
Deleted member 29692
Does the little cap come off of the end letting you get at the screw head with a long screwdriver?
It will probably be bloody tight if it is that.
GJH
29,450
38,827
None, now sold
2006 to 2022
It looks very similar to , obtained from B&Q. It's more obvious on ours that the shank unscrews from the base. Perhaps you need something (rubber gloves?) to enable you to grip both parts to unscrew them.
To reattach, something like plastic wood squeezed into the hole may help.
Mar 10, 2016
558
617
Scotland
A Class RMB 750HE
Three years and counting, 30 years a tent tower.
I have similar ones, The top on mine unscrews. Its on tight so its not obvious. I think you'll find if you turn it upside down the bit the screw goes through is an allen (hex) key hole. Unscrew that bit from the body, re-attach it to the bulkhead then screw the main part onto the hex hole bit, if that makes sense
R
Robert Clark
I find that Araldite (other brands of epoxy resin are available) is invaluable, for minor repairs on the move.
Mix up a good sized dollop - apply some to the inside of the hole in the door and to the screw and the flat plate on the back of the fitting. Screw back into place and hold in place if required with some tape whilst the epoxy sets hard.
Ideally leave overnight to set really hard
May 8, 2016
1,685
80,534
silver coast, portugal
C Class: Low profile
Boatie for 20 years
Had a very similar prtoblem with a boat
Taking apart the door was going to be a nightmare (we all know these things seldom go back together as they should) so retrieving the errant fixing nut was going to take all day with mixed results in refixing door panels
I replaced the screw/retainer with this type of spring toggle:
Now I would use something like this
http://www.toolstation.com/shop/sd9...w=nuts&pmt=b&gclid=CP7cqM3Eu84CFVU_Gwod57QGYA
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
I have one of those 'over the door' hangers you see in the shops.
Bart
Bart
3,188
1,397
Northern Ireland
Since 2016
Thanks all I will have another look at it when I return to the motorhome , and see if I can see an Allen key . If not I'll w8 till I get home and fix it :)
DBK
18,009
48,002
Plympton, Devon
PVC, Murvi Morocco
Just stop washing as well, it will save water and you won't have to worry about where to put the towel. :)
Bart
Bart
3,188
1,397
Northern Ireland
Since 2016
The middle did indeed screw out. Ofc it was tight to start .but got it out..just needed a bit of TLC :)
