how to measure van (1 Viewer)
mjltigger
1,619
2,672
Trowbridge
Autotrail Dakota Max
This feels like a daft question but I'm genuinely confused.
I can't reach the roof of my van from outside and I have a skylight that I know raises the height. I need to book a ferry and want to be sure I get the measurements right so I get the right ticket and have no issues getting in and off the ferry.
How do I measure the height?
Oct 12, 2008
6,297
22,459
Balma (next to Toulouse) France
HymerCamp 51Capucine
Since 2011/owner since 6/03/2014
Take a string , go onto the roof . Once the string touches the ground make a mark where you hold it!
Once back on earth you can measure on the ground
Amicalement
Frankie(y)
Edit: If the skylight is a bit away from the edge you will need a rule or a long stick to go from the skylight to the edge of the van
Reactions: JJ
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
Try googling your make and model and it might give you the dimensions. Remember you might have an aerial too.
C
Chockswahay
It should be in your van makers manual, failing that take the height you can measure and add about 2 inches for government work;)
The ferry people are not too worried to be honest (but you might pay a little less)(y)
mjltigger
mjltigger
1,619
2,672
Trowbridge
I have googled and got a variety of numbers.. I'm more confused by that because the ferry height band is close to the height I've found. I don't have an aerial but the skylight is over and above the standard height.
Is it ok to go on the roof? I'm not light lol
BTW it is a high top transit van conversion
mjltigger
mjltigger
1,619
2,672
Trowbridge
I think I'm going to have to go with over 2.5m which seems to preclude me from booking some ferries. The heights I've found range from 2.25-2.5m and I'm too scared to go on the roof...
Scattycat
920
1,262
Mayenne, France
Rapido
Since 2010
I have a 3 m straightedge that overhangs both sides of the van and is placed across the highest point of the van and I check that it is level with a spirit level. I then measure from the overhang of the straightedge to the ground on both sides and if one side is longer than the other then I take the greater measurement.
Works for me
23,782
133,612
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
When I've booked it just asks below 2,35m in height & 7m in length or under 4,35m in height &10m in length.
for vans it is 2,4m (H) & 6m (L) or 4,35(H) x 6m(L)
Thats dfds. & yes they do check. they have auto height checkers as I accidentally booked wrong & was pulled for it.
312
287
Holmfirth
1990 Gulfstream RV
30yrs
I am sure that the height of your vehicle should be displayed where the driver can see it, or is that no longer required. My RV is just over 11' and there are a good few bridges round our way it would struggle to go under.
andy63
4,672
15,017
south shields
None
since 1990
hi mjltigger, if its a van conversion sounds like mine ...a high roof transit , so makers figures will only give you a guide then add the ht of the protruding skylight for an approx. figure...
scattycat's method is the way to go to give near enough exact height..
I have a dome on now , but seem to remember mine with just a roof light came in at around 2.6 m
Bailey58
8,813
29,534
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
Works for me
I too do that but my van is parked out front on a block paver drive with a natural slope away from the house so a spirit level is not much help. I lay a straight edge over the roadpro dome, the highest point, and make sure it's equidistant height wise from each edge of the van. Then measure as before. As a double check I add the roadpro 40cm to the published height of the van. It takes 3 ladders, 3 tape measures, 4 people and a lot of shouting and some swearing but we get there in the end. :)
DBK
18,023
48,095
Plympton, Devon
PVC, Murvi Morocco
From inside the MH, standing on something, stick your head out of the skylight and look around just to confirm it is the highest spot. Then measure down to the floor and add this to the hight of the floor above ground, which you should be able to measure at the door. I would add 100mm for safety, 'cos if your roof hits the ferry the MH comes off a lot worse.
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
Dave you could have used a satellite theodolite, and use trigonometry, geometry and mathematics getting NASA involved seems a bit much don't you think!!!!!!!?
Take it into boots and put it onto one of those height weight and BMI scales.......sorted you'll have it all.
::bigsmile::rofl::rofl::rofl:::bigsmile:
mjltigger
mjltigger
1,619
2,672
Trowbridge
Thanks for all your replies.. some sound more complicated than others but I'm going to have a go over the weekend..
Vin0114 it is a Transit lwb high top 1999.. brewerydave I'm not sure I can get an accurate measurement because I can't get high enough on a ladder without the virtigo kick in in.. feel free to take the Mickey
devonbeekeeper that was what my OH suggested..no chance of me saying she was right lol...
12,139
18,005
derbys
AUTOSLEEPER SYMBOL
They dont need precision. Unless your van is very low you will be put on ferry with trucks and buses...BUSBY.
mjltigger
mjltigger
1,619
2,672
Trowbridge
I measured in the end... 5.45m long and 2.52m tall.. probably 5cm margin for error based on wobbly ladders lol
12,139
18,005
derbys
AUTOSLEEPER SYMBOL
But if you are >2,35m the price difference to be parked in same spot is nearly double.
Should think only pop tops would come under that height,,,may be wrong. A van of that height could be measured with a clothes prop. Still would not need absolute precision as they allow a decent tollerance. BUSBY.
