Geo
Trader - Funster
- Jul 29, 2007
- 11,757
- 14,565
- Autotrail Tracker FB
- 45 +years with breaks
Taken from SHURflo water pump fitting instructions
To be used after fitting new pipework,fittings or new pump, and for general sanitising the tank and pipe work in situ
use one of the following formula
1, multiply tank size in UK gallons by 0.156
Example 1.
20 UK Gallon Tank is 20 x 0.156 = 3.12 fluid oz of normal domestic bleach
Or
2.Multiply Tank size in Ltrs by 1
Example 2.
80 ltr Tank is 80x 1= 80 Millilitres of normal domestic bleach
Mix bleach and some water in separate container and pour into water tank.
Fill tank with fresh water and run thro all taps Hot and Cold and Shower Head until the odour of chlorine is detected at each Tap
mixed at these strengths the mixture should remain in contact with pipework and tanks for a period of 4 Hrs
Doubling the concentration will take contact time down to one Hr
After treatment drain solution re fill tank and purge all sanitising solution
Two or more rinses may be reqd to rid the system of chlorine odours
Geo
Example 1.
Or
Example 2.
Geo
