How much power to charge a laptop
Discussion in 'Computers' started by keith, Nov 12, 2013.
  1. keith
    keith Funster
    Aug 25, 2007
    3,286
    1,672
    Ecclefechan
    I have a laptop & the power supply states consumption @ 65W. Does this change if the laptop is not on, just charging, or is it always 65W?
    I tend to charge it at night when we aren't using anything else, but would it be better to do it during the day, if not on EHU, as the solar panels are replacing some of the power it is using.
  2. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    best to charge during the day provided you have sufficient solar power.
  3. gozomike
    gozomike Funster Life Member Life Member
    Mar 16, 2010
    876
    663
    Warwickshire - sometimes - but not often
    The 65 watts will be the max for the PSU. Charging plus use will take more power than just one of these.
    When to charge is personal preference, the leasure battery will be charged as you go or the next day. The main thing is not to leave the charger switched on once the laptop battery is charged, if you do it will waste power.
    Mike
  4. hilldweller
    Dec 5, 2008
    27,505
    26,587
    Macclesfield
    Take out battery....
    Mine says 11.1V 4800mAh.
    So 11.1 x 4.8 = 53Wh
    One leisure battery has at least 12V x 50Ah = 600Wh. So it won't make a huge hole in it.
    What I have noticed is a massive kick on the MH ammeter when I hear the hard drive being accessed. That's when the lappy gets hungry.
  5. FM02MZO
    FM02MZO Funster
    Jun 22, 2012
    171
    28
    Castle Donington
    We charge ours via an inverter whilst we are on the move.
  6. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,967
    I normally plug mine in to recharge when it needs it. May be the evening or during the day.
