HOW MUCH BIO LQUID? (1 Viewer)
wingman
1,217
3,333
Romford, Essex
Coachbuilt Lo-Profile
Since 2012
Having previously been firmly in the blue toilet chemical mob, I've been seduced by the 'bio lobby' on here and have bought some cheapo bio liquid for the cassette. Question is, how much does one put into the cassette; a cap full? A quick 'that will do' slop of the stuff? What?
Don't tell me that it's the same amount as goes into a washing machine, because I'm not fully trained-up on washing machines! ::bigsmile:
GJH
29,450
38,827
None, now sold
2006 to 2022
I normally use a couple of capfuls but don't bother measuring exactly so, often enough, the cap isn't quite full. I suppose it's slightly more accurate than "A quick 'that will do' slop" but not much :D
Tincataylor
639
1,360
Devon
Never leave a campsite with your clothes line tied to a lamp post.
If you don't put enough in nature will find a way of letting you know..............I'd give that 5 minutes if I were you........................
Jun 30, 2010
7,924
27,228
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
Having previously been firmly in the blue toilet chemical mob, I've been seduced by the 'bio lobby' on here and have bought some cheapo bio liquid ::bigsmile:
This thursday at ALDI (17th) Toilet liquid going cheap, also other stuff
MattR
4,097
38,558
Beds
Panel van
Years
I put less than a capful in and just top up if required. We very rarely have smells and I'd rather not put more in than is required. If I'm feeling reckless, I'll put some in the cistern to help stop the black algae building up and it tops up the waste tank with bio liquid as it flushes.
Apr 22, 2015
109
132
Wrexham
Auto Sleeper Burford
Since 2014
Hi, we tried using the cheap Tablets but the loo stank worse than not using anything and we don't use it for no 2's, please help us, what are we doing wrong????
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
slap a bit in is what we do, not a capful that is just extravagant . Enough to work and no smells come out either, the solids are no more and it is easy to flush away when emptying the cassette. SOMETIME we cannot empty at an easy to get place, so we change cassettes for the spare and still no smell.
TerryL
6,172
8,175
North East
Low Profile
We use Tesco Biological Liquid and use one capful when recharging. We've found more than that sometimes introduces a chemical smell and generally it's not needed. We also try to empty the cassette daily as it doesn't seem to last as long as the proprietary toilet chemicals, especially in warm weather.
Oct 12, 2011
398
484
West Sussex
Lowline
Since 2011 therefore I'm not a newbie anymore
The answer is to empty regularly, no more than two days or when it begins to whiff!
Anthea M
Oct 18, 2015
9,501
165,143
Sheffield
Hobby
Since 2009
We use the aldi sachet thingys used for washing . Cleans a treat and like @Cyclewalkbob only number ones unless an absolute emergency!
DBK
18,009
48,006
Plympton, Devon
PVC, Murvi Morocco
Are they bio tablets? Try bio liquid next but in places like Spain they don't say anything on the packet as to whether it is bio or not. I understand this is because it almost all is, only we sensitive Brits are offered a choice. :)
And as for the rest of you, are you all constipated? :D
Apr 27, 2008
11,842
14,067
Eastbourne East Sussex
Hymer low profile
Since 1972
Strangely, we have discovered, originally through necessity that using for no 2s and not rinsing when emptying, reduces the smell and breaks things down better. I assume it must set up a sort of septic tank effect.
Don't you love a good toilet thread.
Zoppydog
Jul 19, 2013
335
237
Suffolk
No longer own one
Since 2013
Same here...we stick with the proper stuff and empty frequently, not had any problems since. It doesn't cost that much
Chris
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
If I use it, I put in the whole one litre bottle, but then the black tank is 35gal and it is recommended to be at least 2/3 full before emptying, because then you have a good wooooooosh to get the stuff going down the 3" pipe. :)
Oct 1, 2013
7,503
19,906
Lanzarote
Nil by mouth
Lots
35 gallons of poo and wee ?
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
My Euro Flair has a 160 litre black tank (about 40 US), I used the geo method on my RV and do the same on the Flair. But I modified it to use Bio fluid and Calgon fluid. In my tank I put 2 caps of Bio and 1 cap of Calgon. Occasionally when I know the grey will be going a while I do the same in it. The smell reduction is significant, but the advantage of a tank over cassette on this issue is time to work. Cassette content turnover is usually short. Also with a macerating toilet the contents are already physically broken down so the tank empties easily and cleanly through the 40mm tube. A great advantage over the RV.
Clive
1,296
1,782
Canvey Island
I use the bio tablets because they are easier to carry and just drop 2 into the cassette. Never had a problem with smell, being on my own can be 4 days between emptying. The only issue I get is trying to pee at 30c :(
Mar 21, 2010
2,485
2,992
Bio or Non bio that is the question?Colyboy
