How is this secured?
Discussion in 'Tech/Mech General' started by joggerman, Apr 20, 2010.
  1. joggerman
    joggerman Read Only Funster
    Jul 21, 2009
    139
    6
    Lancashire
    The control panel (electric flush button and indicator light) is not secured on the Thetford fitted to my motorhome.
    It has a rubber seal around and under the top, but no visible means of clipping it down into the main body of the unit.
    Can anyone advise if something is missing, or how it should be secured?
  2. WillH
    WillH Funster
    Feb 9, 2008
    1,745
    1,470
    SW Scotland
    Does it not just pop into the hole? Never had mine out and it looks just the same.
    Bill
  3. joggerman
    Jul 21, 2009
    139
    6
    Lancashire
    no it is just loose if I do that.
    When I first checked, it was 'secured' by the washer being half in/half out of the hole. Obviously not as intended.
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,093
    17,764
    YO11 2BD
  5. shortcircuit
    shortcircuit Read Only Funster
    Sep 13, 2007
    162
    Pump in Daughter's caravans Thetford stopped working and as usual "Dad". I puzzled as to how to gain access. In the end prized off the top panel which I found is just held on by mastic which was not well applied. Repaired pump and sealed back down with mastic.
  6. joggerman
    Jul 21, 2009
    139
    6
    Lancashire
    There is obviously some sort of retaining ring missing.
    However, I have solved the problem by putting self adhesive velcro strip arround the switch unit, which makes it grip the sides when pushed in, but allows for easy removal.
    Thanks for the suggestions.
