Hi all. Friend has a 2013 Tracker RB and has damaged the panel below the rear lights on the passenger side. He has had a new panel delivered and so needs to get the light unit off to get at the panel fixings. Does anyone know how the light cluster comes apart?
There should be 2 red "plugs" in the lens, ease them out and 2 screws should be there, undo these and the unit will detach, OR ease the light unit out CAREFULLY, using 2 flat blade screwdrivers,depending which type it is.
