How do you rate the Hymer B654 Legend 2006? (1 Viewer)
Feb 19, 2015
1,776
1,249
Norfolk
Globecar Campscout 2013
Since 2016
We are shortly to buy this as our first-time motorhome to include ski trips and hopefully a lot of fulltiming.
Did we pick well in your opinion?
Lenny HB
53,306
149,488
On the coast in West Sussex
Hymer B678 DL
Won't go far wrong with a Hymer, French bed layout works well if you don't need a garage, out last van was a Hymer Tramp with the same layout served us well. What is the gross weight as if only 3500kg you may need to upgrade to get enough usable payload.
scotjimland
2,249
9,760
A Woosh bang
What Lenny said.. and if full timing you WILL need as much payload as possible and I would also consider a model with a garage.. being ex full time I know how much stuff you take.. for me a garage would be a 'must have'.
ex factory, our B644 garage model has 1,000kg. payload
Lenny HB
53,306
149,488
Hymer B678 DL
Is it by any chance the one at Becks, if so & you are not going to use the towbar I would get rid of it, they weight between 50 - 80kg and all behind the rear axle.
Jac Sprat
Feb 19, 2015
1,776
1,249
Norfolk
Since 2016
I believe it's payload 680 kg and MTPLM 3900 kg
Does that sound ok? and what is,MTPLM PLEASE?
Jac Sprat
Feb 19, 2015
1,776
1,249
Norfolk
Since 2016
No it's a private sale. But got the specs from their advert . Presuming all 2006 B654 Legends are the same?
Lenny HB
53,306
149,488
Hymer B678 DL
MTPLM is Gross weight, the maximum total weight of the vehicle.
With a MTPLM of 3900 kg less 680kg payload will give a MIRO (mass in running order) of 3220kg. Hymer specify the MIRO including a driver at 75kg, 20Lt of water, 90% fuel & one 11kg aluminum gas bottle.
To know what the real payload is you need to deduct any factory fitted & dealer fitted extras, e.g. it will probably have a comfort pack which will include a drivers door, oven , larger fridge, awning, 2nd battery, steel gas bottles etc.
Ask to look at the Certificate of Conformity, under the Mass in Running Order there will be a line "Technical Mass in running Order" this will give the MIRO when it left the factory i.e. including factory fitted options.
Lenny HB
53,306
149,488
Hymer B678 DL
No, there will be an options on weights and chassis, basic will probably be 3500kg with a 3850kg option (3900 sounds odd) or the maxi chassis's at 4250kg with an option of 4500kg.
Jac Sprat
Feb 19, 2015
1,776
1,249
Norfolk
Since 2016
This van doesn't have a tow bar and it does have a comfort pack like you described.
Jac Sprat
Feb 19, 2015
1,776
1,249
Norfolk
Since 2016
Much appreciated Len!
Jac Sprat
Feb 19, 2015
1,776
1,249
Norfolk
Since 2016
So Lenny does that weight/ payload sound ok to you ?
Lenny HB
53,306
149,488
Hymer B678 DL
Yes I think it is OK, for normal use, but could be a bit tight for full timing.
If you are serious about full timing you need to get confirmation of the gross weight and before completing the sale get it to a weighbridge, also check front and rear axle loadings. If it is on the maxi chassis shouldn't have any problems, but the light chassis can get tight on the rear axle.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
You might have a word with existing B654 owners and get their opinions before purchase. Theonlysue and Ambilkate each have one I think.
Ambilkate
8,651
18,054
Shropshire
HYMER 654
since 2006
Ours is a Hymer B654 2004 only had her for a few months. It is has MTPLM of 3900 kg its on a Alko chasis no problems with payload its enough for what we carry and our needs . We had been looking for this model Hymer for 4yrs we are very pleased we now own one :) regards Kate x
ps @Theonlysue has a 2006 model she may be the best person to advise . Have messaged her to tell her about this thread
