How do you jack up your van? (1 Viewer)
Doodlebug
140
Surrey
When changing a wheel or for general maintenance what do you use to jack up your van.
I tried to lift the van yesterday with the supplied jack and it did not feel safe at all, in fact I did not continue and thought I would use my trolley jack that I use on my other cars, this too did not lift the van enough which is ok as it is only rated at 1.5 tons.
I am looking to purchase a higher rated jack and wondered what you knowledgable people use.
Thanks in advance.
::bigsmile:::bigsmile:::bigsmile:
Sep 23, 2007
1,709
1,970
Leicestershire
4 and many as a tugger
I use a 3T trolley jack. I tried a 3T trolley jack from machine mart and it was crap. But at under a £100 I suppose it was to be expected.
Andy
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
At the risk of stating the bl**ding obvious - the jack that comes with the van. The standard Sprinter jack is a hydraulic pillar version that is capable of lifting the vehicle high enough to do the job. I also carry a 1 1/2" thick block of oak to place under it in the event of soft / uneven ground: otherwise it tends to sink!
Only had to do it once in anger.
Philip
Douglas
2,835
400
South Wales,
6 years + 5 years in boat before that
The scissor jack that came with my Fiat based Swift is basically dangerous as its unstable, partially due to the fully loaded condition of the MH.
When I am at home I use a 3 ton trolley jack and when traveling I use two 3 ton hydraulic jacks. and if possible I find something to use as blocks too add to the safety.
Doug...
Doodlebug
Doodlebug
140
Surrey
Doug...
Doug
The two 3 ton hydraulic jacks are they bottle jacks?
Regards
Doodlebug
Doodlebug
140
Surrey
Philip
The jack that comes with the van is a scissor jack and does not feel stable at all.
Jan 27, 2009
872
3,358
Leyland Lancs
since 2001
Doug...
I do the same as Doug and use a 3 ton trolley jack at home, but am unable to find any hydraulic jacks that will fit under the low rear jacking points of the Alko chassis.
dikyenfo
44
lincoln
A class Mc Louis with small trailer
1 year
Ex army screw jack for me. Broad base and huge lift height. These can be got dirt cheap from the right shops that deal ex military. Altho. fairly heavy they are lighter than my 3-ton hyd. jack and a lot more compact.
VMax666
172
6
Knutsford
2yrs
Whichever jack you use, you MUST put an axle stand under before doing anything else. Hydraulic jacks can lower slowly if the seals are suspect or even drop quickly as Len Fairclough found out many years ago! VMax
Doodlebug
Doodlebug
140
Surrey
Good old Len Fairclough, liked a swim if I remember correctly. :thumb:
iceni
300
117
Birmingham
Lowline Coachbuilt
27yrs
Im glad you posted this.
I had to change the wheel on my 09 Boxer last week and the scissor jack was worse than useless. the jacking point is a short bit of 1in pipe welded under the chassis which the top of the jack goes into. Not only was it hard to jack up but the jack squealed and groaned when i was doing it and it started to tilt over.
I am looking at other options now like air jacks. There are also quite a few bottle jacks on ebay that can be done by hand or a tyre air compressor
As other have said a trolley jack is Ok if you have room and can take the weight.
Phill
Doodlebug
Doodlebug
140
Surrey
Phill
Thats exactly what happened to my scissor jack, it did not give me any confidence and I would be reluctant to try it again so I am on the lookout for a better solution.
sedge
Jul 7, 2009
5,502
13,085
Nr Jct 3 M6
C class
Aug 09 to date 9,000 miles!
So what happened to Harry Hewitt then?
43,304
49,293
the standard, supplied scissor jack isnt meant to be use with the van fully loaded.
i had to use mine once at the front as the hydraulic jack failed (lack of oil and maintainance:Blush:)...never again:Eeek:
rainbow chasers
3,680
1,725
Mid Cornwall
Various
Trolley jack at home, with the bottle jack as back up (Usually find with the rear end, you need two - one to go so far, then another lifted into block to go the rest of the way and clear the skirt)
Bottle jacks can be bought fairly cheaply, rating up to 6 ton and easily stowed - which is my main preferance to them - trolley jack is never all that good for dragging round the country unless you have a large garage!
As always, carry chocks - or use the levelling ramps to chock the wheel.
Douglas
2,835
400
South Wales,
Doug
Regards
Yes, They are bottle jacks, I dont have an alco chassis though and the jacks are about 8" high which gives plenty of room to get them under the van. Now this might upset you a bit, I bought the jacks in Lidl at Tavira for 14 euro's each.
Doug...
VMax666
172
6
Knutsford
2yrs
Sedge- you are right. It was Harry Hewitt who was crushed under a car, Len had a heart attack according to wiki. Still think he should have used an axle stand. Moral is don't live in Coronation St or Emmerdale if you want to live a long and normal life. VMax
KenandSue
39
West London
Less than 1
I should steer clear of Albert Square as well - they've had more than an acceptable level of weird and wonderful deaths!! :Eeek:
