How do you check if a solar panel is working?
Discussion in 'Motorhome Chat' started by Encantador, May 14, 2012.
  1. Encantador
    Encantador Funster
    Jul 2, 2011
    835
    312
    UK
    Whenever I check the control panel with everything in the hab area switched off, it always shows 0.35 is leaving the hab batteries. I don`t have any problems with the hab batteries going down so assume this is normal.
    Yesterday, I checked in glorious sunshine which had been shining for a few hours and it still said the same.
    Does this mean the solar panel can`t be working, or does it not pass through the control panel maybe?
    Steve
  2. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,187
    15,162
    Leeds the one up North
    What is the voltage reading?
  3. slobadoberbob
    slobadoberbob Read Only Funster
    Jun 1, 2009
    6,159
    1,970
    Kent, garden of England
    you could try frying an egg on it
    :Rofl1::Rofl1::Rofl1::Rofl1: you could see if you could fry an egg on it:Rofl1::Rofl1::Rofl1: make a great griddle pan if they do not charge the batteries:Wink:
    Bob:Blush:
  4. Encantador
    Encantador Funster
    Jul 2, 2011
    835
    312
    UK
    Not quite sure what you mean, the hab batteries (2 x 110v) usually show 14v+ when on ehu, I suppose if they are full, that could be why.
  5. Encantador
    Encantador Funster
    Jul 2, 2011
    835
    312
    UK
    :Rofl1:
  6. Techno
    Jul 28, 2010
    14,187
    15,162
    If you turn the charger off then you'll see if the solars are charging. With no charge at all the voltage will drop gradually to about 12.6 but solar will hold them at 13.4 float charge
  7. Encantador
    Encantador Funster
    Jul 2, 2011
    835
    312
    UK
    Thanks, will give it a try.
  8. vwalan
    vwalan Funster
    Sep 23, 2008
    7,630
    3,926
    roche cornwall
    you could put a volt meter on the ingoing cable connections on the regulator . take a reading then go back at night it wont read anything .check it with lots of sun on it as well. check the out side of the reg and see what that reads . you soon see a pattern of whats happening.i use a cheap alternator /battery meter from aldi. differant coloured lights show up. and as the reg is a pulse width mode .i can very often watch it pulsing . soon after that the batts are full and it sttles down to steady lights .
