How do you change a rear light cluster bulb on a 2010 Comanche?
Discussion in 'Motorhome Chat' started by Brightspark, Apr 11, 2013.
  1. Brightspark
    Brightspark Funster
    Dec 27, 2010
    240
    107
    Northallerton , North Yorkshire
    Not that I need to, but I can't see how you would be able to change a bulb, as the lenses don't move/unscrew & the back of the clusters are hidden by a rear bulkhead. Hopefully I have uploaded the picture correctly to show the predicament.
  2. Phill D
    Phill D
    Dec 6, 2011
    4,414
    4,632
    South Wales
    do they unscrew individually or a push and turn locking mechanism ?:Doh:
  3. Brightspark
    Brightspark Funster
    Dec 27, 2010
    240
    107
    I have tried unscrewing & a push in & turn test but each individual lens cover won't move. Other than ringing the dealer i'm at a loss as to how they come off.
  4. Phill D
    Phill D
    Dec 6, 2011
    4,414
    4,632
    South Wales
    its a call to the dealer i think. a wrong move could be costly:Doh:
  5. SIFTA SAM
    SIFTA SAM Funster
    Jan 27, 2009
    459
    456
    Leyland Lancs
    This is from another forum in reply to the same question.
    Just had email from Auto Trail;;
    To remove the light you need to insert a small flat screwdriver between the plastic and the bottom edge of the light. I would place a cloth between the red plastic and the screwdriver so you do not mark the plastic. You will see a narrow slot in the base of the light. The light is held in place with a spring clip.
  6. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    some of those round type lights have 3 screws that hold them in from the front but they would be behind the red trim which may just be held with an industrial variant of velcro.
    if you can get to look up from under the van you may see something obvious.
    there are some round lights that just push into a hole and are held with a couple of spring clips.
    there may be some info here..... http://www.jokon.de/en/catalogue-2011.html
  7. Brightspark
    Brightspark Funster
    Dec 27, 2010
    240
    107
    Thank you 'sifta sam' I can see that there is a slot at the bottom of the lens & will try in daylight to get one off.
  8. haganap
    haganap Funster Life Member
    Dec 5, 2007
    11,131
    13,880
    Heavan
    I have a similar cluster, Believe it or not it is held on by velchro and also some plastic popper things. Took me ages to work it out, you have to pull and prod very carefully.
    • Like Like x 1
