how do I use my laptop?
Discussion in 'The Beginner' started by CWH, Feb 3, 2014.
  1. CWH
    CWH Funster Life Member
    Jan 29, 2014
    3,111
    13,589
    under a wand'rin' star
    Total ignoramus here, not a clue on electrics...
    Just bought a m/h, dealer says I should use 12v everything or if on EHU I could "blow" the electrics of the whole site.
    So how do I use my laptop? (probably just to check emails & browse for the next site along the trip).
    Similarly - can I do this off EHU or am I going to do something drastic to the m/h?
  2. Trikimiki
    Trikimiki Read Only Funster
    Oct 14, 2012
    538
    1,026
    Glasgow
    If that was the case there would be no point going onto EHU. I personally just try to keep it below 4KW on at any time and to date has worked. Either use Lappy on battery or just plug it in on EHU as you would at home.
    • Like it Like it x 1
  3. joner8888
    joner8888 Read Only Funster
    Jan 4, 2012
    2,190
    1,971
    somerset
    You won`t blow the (whole) site :Doh:
    Every site pitch has a trip switch so as you don't either use too much electric or you have a fault.
    • Like it Like it x 2
  4. daveandsan
    daveandsan Funster
    Dec 10, 2013
    1,396
    1,982
    South Staffs
    Just plug your laptop into the 240 socket if you are on EHU, the dealer is talking a load of rubbish, if you had the kettle on together with the toaster the most you would do is trip the overload breaker. :Smile:
  5. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,778
    10,189
    most ehu supplies in this country are rated at 16a but a safer max load would be 13a or 3kw. so if you have the heating on, turn it off whilst boiling the kettle etc. this is the reason caravan/motorhome kettles/toasters/etc are low wattage and not as fast as home versions
    as for a laptop, if on hookup use as normal as they only draw 80w at maximum. if off hookup, pick up an in car 12v charger, much more efficent
  6. Roxie
    Roxie Funster
    Jan 9, 2013
    126
    100
    Newbury
    May be worth investing in a second battery for your laptop, and keeping it topped up when you have EHU - my no. 1 battery doesn't hold its charge for long. I also use the inverter occasionally, but it does drain the power quite fast.
    Or invest in an Ipad, which has a USB / 12v charger...
  7. Gizmouk
    Gizmouk Funster
    Nov 6, 2013
    1,011
    1,798
    Essex
    To put it in laymans terms: The dealer is full of shit.
    When on EHU, just use your lappie in the same way you would at home :thumb:
    • Like it Like it x 9
  8. CWH
    Jan 29, 2014
    3,111
    13,589
    I feel better now!
    Thanks everybody, all your VERY QUICK responses make me feel much better!
    It's great not to be made to feel THICK as a complete beginner (I've noticed some very unkind replies on other forum sites but never on this one)
    Off for our first few days away on Thursday - hope we don't float away in the floods.
  9. Roxie
    Roxie Funster
    Jan 9, 2013
    126
    100
    Newbury
    Just make sure you're on a hard standing - we managed to get stuck in the mud when we took Roxie our on her first trip, in January 2013!!
    :Blush:
  10. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,961
    12,243
    Plympton, Devon
    You should be able to run your laptop off a 12 volt cigarette lighter socket. Just Google your laptop's model number followed by "car charger" and you should find something suitable. Of course if you are on EHU use your normal charger.
  11. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,116
    17,785
    YO11 2BD
    no such thing as a stupid question....if you already knew the answer you wouldnt be asking.
    And as you are asking makes you far from thick, it makes you sensible...we were all newbies once.
    There are very few rules on FUN and number 1 rule states you do not attack/abuse a poster....no matter how/what you feel...and as a whole that rule is adhered to strongly
    • Like it Like it x 3
  12. cmcardle75
    cmcardle75 Read Only Funster
    Jun 8, 2012
    670
    263
    Reading
    Basically, it depends if you are intended to use campsites with electricity, or to use cheap campsites/wilding sites without. If you have electricity, even the most miserly Mediterranean site will have enough juice to power a laptop. If you don't intend to have mains electric, you should get a 12V laptop power supply and charge it whilst driving (or fit solar).
    Something like the following will cover most laptops.
    http://www.maplin.co.uk/p/12v-auto-...ter-with-1a-usb-socket-12-charging-tips-a83la
  13. sleep e carr
    sleep e carr
    Nov 30, 2008
    109
    31
    Whitby North Yorkshire
    When I go away I use my lappy all the time if on elec plug in like normal, or I use an adapter that I bought in a electrical store for £17 you can adjust the voltage on a slide button, my internet I get via a 3dongle in usb.
    It works great even in europe hope this helps.
  14. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,396
    5,423
    East Sussex 01-580-881288
    Now all you need to do is Subscribe , here to get all the benefits of being a Funster:thumb:
    Funsters only extract the urine in a friendly way:Rofl1::Rofl1::Rofl1:
    Peter
  15. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,945
    3,401
    Eastbourne East Sussex
    Often cheaper to get a dedicated 12v charger off eBay for your actual model of laptop. I have one for my dell which is great. I don't even use the mains charger when on ehu, as the ehu is recharging the battery.
