How do I reset Schaudt dt201 panel?
Discussion in 'Tech/Mech General' started by Theonlysue, Dec 24, 2015.
  1. Theonlysue
    Theonlysue Funster Life Member
    Sep 14, 2009
    3,068
    2,938
    Essex
    My panel is confused.
    It is saying the leisure batteries need charging as it has been 20 days since last charge, but if I press the battery button on panel, it flashes 50% with the error message;
    CHARGE DATE
    however, I have been on hook up for 3 weeks, so if I then press the + button on the panel after the battery button, it has lost the date at this point, so it has nothing to compare it to.
    The time, date and year are correct on the main front display, so perhaps a panel reset may get it back on course? How would I do this??
  2. SandraL
    SandraL Funster
    Jan 24, 2012
    295
    153
    Somerset
    I'm sorry but I dont know the answer but you could try ( without too much hope) the following
    1 Shut panel down as per manual, section 3.7 and start up again.
    2 Try resetting the battery capacity, section 3.5.2.1
    Copy of the manual is at
    http://www.hymerclub.co.uk/control panel 201.pdf
    As many have said udo lang at schaudt is extremely helpful but will be on holiday I'm sure!
    Udo.Lang@schaudt-gmbh.de.
    If you contact udo please tell him which version of software you are using, see manual 3.5.1, bottom right hand of picture, software version will be U2.16 or similar, possibly need the 4 digits as well?
    Good luck!
  3. Theonlysue
    Sep 14, 2009
    3,068
    2,938
    Essex
    Thanks for that, and yes, he is on holiday :)
  4. Theonlysue
    Sep 14, 2009
    3,068
    2,938
    Essex
    Couldn't download manual.
    Switched panel off.
    Switched ekectrobloc off.
    Pulled leisure battery fuse out.
    Reversed all.
    Date warning has gone, just says CHARGE now.
    Says batteries at 50% but am.om hook up and says 14.1v which is the final charging voltage.
    So half way there.
    Any further ideas ???
  5. Theonlysue
    Sep 14, 2009
    3,068
    2,938
    Essex
    Switched panel off.
    Reversed all.
    So half way there.
  6. bjandlin
    bjandlin Funster
    Feb 29, 2012
    176
    98
    Reading & Surgeres France.
    Good morning, having had conversation with Udo over a similar problem he suggested that you should have a break from continual hook up.
    Disconnect & let the battery voltage drop maybe over 8 or so hours, reconnect & check charge again.
    May help.
    Barrie.
    • Like Like x 1
  7. Zigisla
    Zigisla Funster
    Oct 24, 2015
    1,108
    1,297
    Fareham, Hants
    Yes Udo is on hols until 11 Jan - Auto Out of Office reply from him
    Sehr geehrte Damen und Herren,
    ich bin vom 23.12.2015 bis zum 11.01.2016 nicht in der Firma erreichbar.
    In dringenden Fällen wenden Sie sich bitte an
    Kundendienst@schaudt-gmbh.de
    oder telefonisch an unseren Kundendienst: 07544-9577-16.
    Mit freundlichen Grüssen
    Udo Lang.
    Ladies and Gentlemen,
    I am from the 23.12.2015 until 11.01.2016 not in my office.
    In urgent cases, please contact
    or call our German/English customer service: 07544-9577-68.
    Best Regards
    Udo Lang.
    Sitz der Gesellschaft: Markdorf - Registergericht Freiburg HRB 580293
    Geschäftsführer: Barbara Härle, Armin Steinmetz
    Die Informationen und Anlagen die in dieser email enthalten sind sind vertraulich und ausschließlich für den Gebrauch des beabsichtigten Empfängers bestimmt.
    Jegliche Verbreitung, Verteilung, die Kopie oder der Gebrauch dieser Informationen ohne vorherige Erlaubnis von Schaudt ist ausdrücklich verboten.
    The information and materials contained in this email and any attachment are confidential and solely for the use of the intended recipient.
    Any dissemination, distribution, copying or use of this communication without prior permission of Schaudt is strictly prohibited.
  8. SandraL
    SandraL Funster
    Jan 24, 2012
    295
    153
    Somerset
