How Big? How many holes and how long?
Discussion in 'Tech/Mech General' started by American Dream, Sep 12, 2009.
  1. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Well
    How Big is yours?
    How many holes does it have?
    AND how long does it take you to..............
    Refill your LPG Tanks?
    :Rofl1::Rofl1::Rofl1::Rofl1::Rofl1::Blush::Blush::Blush:
  2. 656
    656 Read Only Funster
    Jul 30, 2007
    1,150
    291
    The universe
    I have 1 hole where the filler is fitted and 2 x 11kg tanks -44litres Takes 3 - 5 mins to fill depending on how much LPG is needed.
  3. Munchie
    Munchie Funster Life Member
    Jul 28, 2007
    8,609
    11,890
    Champagnac-La-Riviere
    Ditto :Laughing:
  4. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Cheers Guys.
    My Gaseous heap is having 2 x 100 litre tanks fitted.....
    Should I go down the pub while it's filling?
    Oh.....They are 4 hole tanks.
  5. olley
    olley Funster
    Jul 29, 2007
    3,840
    2,392
    Ipswich
    Hi Ad, you can have a dozen holes, won't make any difference, your fill rate will be dependant on your pipes from the filler to the tank, Probably 8mm. Pubs a good idea if you can get the wife to hold the gun. :BigGrin:
    Olley
  6. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Hi Olley.
    The filler hose to the tanks is definitely bigger than 8mm.
    Was looking at fitting a "t" piece with non-return valve between the 2 tanks.
    Then it's 8mm all the way to the vapouriser and mixer...
    The pub sure sounds good.
    Are there any that also sell LPG........No Not to drink......:Doh::Rofl1::Rofl1::Rofl1:
    PS Missus with a gun..........NOT a good idea,WHAT were you thinking?
  7. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,903
    13,942
    Norfolk
    Mine has 2 90lt tanks about 80 lt nett two fillers on either side and one domestic 63lbs however many lts that is. When I filled up with autogas today (Flogas) the pump had a pressure gauge which read 200 psi. How can it be so slow at that pressure ??
  8. olley
    olley Funster
    Jul 29, 2007
    3,840
    2,392
    Ipswich
    Because its pushing the liquid gas into the tanks which are already at over 150psi
  9. Tony Lee
    Tony Lee Read Only Funster
    Sep 28, 2008
    274
    Inside diameter that counts.
    Fill rate is probably determined more by the pump than diameter of pipes with the main problem being that a higher fill rate requires a higher pressure differential and more chance of damage to the gas side of your installation ie the regulator.
    What do you mean by "4 holes"
    Can see a need for separate liquid inlets so you can just fill one tank to reduce weight, and there will be separate gas lines out of each tank but ???
