hot rod waterheater (1 Viewer)
LyndonRV
185
9
Cheshire
RV
2 years
my rv is in travel world having some work done. when i got the rv from new the only way to heat the water was by gas i have spoke to simon at tw and he tells me it is danderus to put a hot rod in is this true?
Jul 29, 2007
6,551
39,642
Ipswich
RV and PVC
30 years
Hi Lyndon never heard that before, plenty of people fit them and mine has one as standard from Winnebago.
Olley
scotjimland
2,310
9,981
A Woosh bang
that's an odd remark from Simon.. don't know how it could be dangerous, :RollEyes:
I fitted one two years ago.. saves a lot of LPG
:thumb:
Jim
zaskar
1,159
371
UK
5th Wheel
It depends on your interpretation of dangerous!
You're not going to blow up for a start.
What Simon probably meant, and should have explained better, is that in the Atwood and Suburban water heaters, there is a sacrificial annode rod (if you look at your water heater, its behing the large 1" drain plug nut at the bottom/centre of the boiler end plate).
To fit a HOTROD 110v heater, you unscrew the annode rod and screw in the HOTROD in its place.
The "upside" is being able to heat water using the electric that you're paying for anyway.
The "downside" is that remeoving the annode rod means that if you get a crack in the ceramic cooating which coats the inside of the boiler, the metal casing WILL corode a lot faster and eventually perforate leading to leaks.
To pays your money and you takes your chioice!
Jim
Ringleader
Jul 19, 2007
36,404
130,782
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Strange he should say that, they are an optional extra, you already have an indicator
light for it in your control panel.
scotjimland
2,310
9,981
A Woosh bang
My heater came fitted with a sacrificial anode ring around the base and a spare .. so that theory doesn't hold true for all heaters..
I forget the name of it , Linda supplied it .. Hotrod is used generically, ( same as Hoover is used to refer to vacuum cleaners,) when referring to water heaters, perhaps Hotrod doesn't have one ?
Jim
LyndonRV
LyndonRV
185
9
Cheshire
RV
2 years
simon told me if thay have any rv in with a hot rod fitted thay take it out and throw it away does any body now of any one ho can fit one for me
zaskar
1,159
371
UK
5th Wheel
My heater came fitted with a sacrificial anode ring around the base and a spare ..Jim
That's a new one one me. only ever seen the rods of 1" dia X 6" long.
Is yours some sort of ring around the back of the nut? through which you can also insert a Hotrod?
LyndonRV
LyndonRV
185
9
Cheshire
RV
2 years
my rv is a holiday rambler arista 310 2008
scotjimland
2,310
9,981
A Woosh bang
Exactly .. the heater element goes through the ring, so it must be a smaller dia than the 'Hotrod'
As I recall the heater element's longer than 6" and about 1/2" dia
Linda will have full details ..
Jul 29, 2007
6,551
39,642
Ipswich
RV and PVC
30 years
Yea right and RV's do 20mpg, sounds like bulls**t to me.
I can just see a dealer spending time removing a hotrod on the off chance that somewhere down the line it's going to cause trouble.
Olley
zaskar
1,159
371
UK
5th Wheel
Oye Linda!!!:ROFLMAO:
Come on, spill the beans, I definately want one of these.::bigsmile:
Best of both worlds.::bigsmile:
L
Lindy-C
Jim
If I recall, you have the Lightning rod Jim....from the feedback I have received, easier to install than the Hott Rod..
scotjimland
2,310
9,981
A Woosh bang
Thanks Linda ..
That's the one.. you can see the anode ring on the brass fitting, it comes with two different sized fitting bushes.. the anode ring can be used from the spare bush.
Takes about 15 mins to fit .. wiring the 110v supply takes a bit longer :roflmto:
