Hot Air Constantly ON
Discussion in 'Tech/Mech General' started by Spinout, May 29, 2014.
  1. Spinout
    Spinout Read Only Funster
    Apr 17, 2014
    30
    London
    I have a FF Tabbert, Alko chassis with a Fiat drive chain 1987.
    The problem is the heating and too much of it. The knob is in the cool position ie all the way to the right, its still pumping hot air into the cab.
    Where do I start looking to remedy this.
    Many thanks
    :thumb:
  2. Tootles
    Tootles Funster
    Sep 14, 2013
    9,322
    33,524
    Lancaster
    Your heating system is right on the crux of change, but I think that the control lever pushes a vent to the inside of the cab for hot, or the outside for cold. You may be able to lie on the cab floor, look up, and shove the panel to vent outside with a screwdriver, as a short term measure. If it is the sliding vent type, they work on a cable, which probably wont have snapped, but the plastic holding clip may have.
    If it's the earlier type, the hot water is switched off by a cable control to an engine valve, but I think it's the vent panel with yours.
  3. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,630
    3,462
    Telford, Shropshire
    1987 Fiat base is also known as Talbot Express, the hot cold control on the dash connects to a tap in the heater circuit under the right hand side of the dash. Its not unknown for this tap to sieze up and/or the operating cable to come off. Replacement valves are not available anymore but I have known a simple gate valve to be fitted on the heater pipe allowing manual control, albeit b(y) fiddling around in the right hand footwell.
    D.
    • Like it Like it x 2
  4. Tootles
    Tootles Funster
    Sep 14, 2013
    9,322
    33,524
    Lancaster
    Thanks Dave, I was struggling with the year as to which system was fitted. :thumb::thumb:
  5. chrisgreen
    chrisgreen Funster
    Jul 26, 2009
    5,668
    7,793
    england
    someone might have bypassed the heater matrix control valve,because it was leaking or faulty:cry:
  6. magicsurfbus
    magicsurfbus Funster
    Oct 11, 2010
    3,896
    8,994
    NW England
    A knob producing too much hot air eh?
    Was your van pre-owned by a politician?
  7. Spinout
    Apr 17, 2014
    30
    London
    More than likely!
    Thanks everyone. I managed to close the valve manually, under the dash which seem to do the job.:thumb:
