Hook up
Discussion in 'The Beginner' started by combi, Apr 4, 2011.
  1. combi
    combi Read Only Funster
    Aug 23, 2010
    64
    9
    Me again !!! Just a very quick question - when my van is parked at home should I leave connected to the mains or just let it charge via the solar panels ?
    Thanks to everyone for their kind replies to my questions.
    Regards
    cakeboy
  2. 656
    656 Read Only Funster
    Jul 30, 2007
    1,150
    291
    The universe
    I hardly ever go on hook up and let the Solar panels do their job and charge all the batteries including the starter battery. After all, they were designed to do just that!
  3. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,275
    7,941
    West Norfolk
    We always leave ours on hook up for a maintenance charge to be maintained.
    Then again, we don't have solar panels!!!:Smile:
    Be green and let your panels do the work!
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,947
    17,612
    YO11 2BD
    depends on the type of onboard charger fitted..
    a standard charger.....turn it on every 2 or 3 weeks for a day.
    can overcharge the battery and boil it dry if left on indefinately.
    a smart charger...leave it on full time if you want.
    only puts in what the battery needs.
    solar panels should keep it charged as you arent using any power at home.
    check the battery electrolyte level from time to time and top up with de-ionized (distilled) water if needed...not tap water !
  5. 1948
    1948 Read Only Funster
    Dec 3, 2009
    444
    46
    surrey
    I also had solar panels fitted and in winter months I have the van on hook up with timer which comes on between 7pm to 5am and I leave an oil fire heater connected on 1kw setting. and and do not do any winter precautions except empty the fresh/ waste tanks, no hook up from April onwards
  6. barryd
    barryd Read Only Funster
    Feb 10, 2009
    1,144
    103
    Yorkshire Dales
    Just to be different I dont have solar panels and I dont bother with hookup at home either. If Im going on a trip where there is no hookup I might plug it in for a few hours before we go. That and the drive to where ever I am going charges the battery. If I am going to a CL with hookup I dont bother plugging in before we go as there is no need.
    Hasnt seemed to cause a problem so far.
  7. WynandJean
    WynandJean Funster
    Mar 23, 2010
    2,536
    1,421
    West Midlands
    We usually put ours on prior to going away just to get the fridge up to (down to!) temp. And always leave fridge door open when it's switched off so you don't get mould.
    Wyn
  8. scotjimland
    Jul 25, 2007
    28,934
    25,602
    Just to be different, No 2 .. :Wink:
    Never had solar panels, never needed them .. and at home, I always left mine on hook up 24/7 .. and the fridge 'on'.. ready for the 'off' at a moments notice..
    never had a battery problem ..
    but as papajohn said, if you plan to do this do check you have a multistage charger otherwise you will boil the battery(s) dry.
