hook up box
Discussion in 'The Beginner' started by Bruce, Jan 30, 2013.
  1. Bruce
    Bruce Funster
    Aug 12, 2012
    147
    51
    Glasgow
    Hi just received hook up box but no instructions and have a couple of questions. The box has a rubbery foam type of gasket ,does this go inside van with silicon outside or does this simply act as a gasket between van and box. Also no marks inside box to indicate wiring i e live and neutral. Any help......Bruce
    PS Can I use normal house 2.5 cable to the RCD
  2. Gooney
    Gooney Funster
    Jun 2, 2010
    4,772
    7,864
    Flintshire
    I was recommended not to use house wire, it's single strand and not very flexible against vibration, you need multi strand cable.
  3. hilldweller
    Dec 5, 2008
    27,554
    26,665
    Macclesfield
    Gasket between plastic and van body. Possibly better to bed it down on a good mastic, depends how good the foam looks.
    If you mean mains twin and earth, bad move in a vibrating vehicle, use good quality flexible.
  4. Bruce
    Bruce Funster
    Aug 12, 2012
    147
    51
    Glasgow
    thanks for reply will take advice onboard
  5. Bruce
    Bruce Funster
    Aug 12, 2012
    147
    51
    Glasgow
    Thank you for advice, any idea for wiring this up please also whats the plastic springy thing inside box for...Bruce
  6. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,619
    5,689
    Yr Wyddgrug
    Plastic springy thing is to allow you to release external plug. That is if I understand what bit you mean.
  7. Terry
    Terry Funster
    Dec 27, 2007
    10,771
    6,291
    South yorks
  8. scotjimland
    Jul 25, 2007
    28,940
    25,628
    16th Edition IEE Regulations
    This is a very useful guide for Caravan Electrical Installations.. (same as motorhome)
    http://www.tlc-direct.co.uk/Book/7.9.2.htm
    If in any doubt about any aspect of your installation consult a qualified electrician... don't make educated guesses.. getting it wrong can be fatal.. in more ways than one.
