Hook-up at home/ winter blues
Discussion in 'Motorhome Chat' started by John Hinch, Oct 22, 2013.
  1. John Hinch
    John Hinch Funster
    Sep 3, 2013
    8
    Donington, Spalding
    Newbie again. We have been wondering if it is beneficial to leave the 240 volt hook-up on 24/7 whilst we are at home and the motorhome is parked on the driveway. We see lots of caravans and motorhomes parked up for long periods with the power connected constantly.
    Also, if it is advised to leave some form of heating in the motorhome through the winter freeze what is the recommended and most economical type.
    Thanks - John & Jan
  2. cranky
    cranky Funster
    Oct 29, 2012
    401
    461
    essex
    I leave mine hooked up 24/7 when at home, just ensure that your charger is ok to do the same. I dont normally bother with heating but a small convector heater on low would probably be all you would need.I tend to give it a run every couple of weeks for at least 30 mins up the road and back just to keep everything working and warmed through.
  3. camcondor
    camcondor Read Only Funster
    Jul 27, 2007
    1,044
    478
    East Midlands
    There are probably loads of overwintering threads to read through, but what we did which seemed to keep our motorhome dry and fully charged when parked up at home as to keep it on permanent hook up. The batteries maintained a good charge for years that way, and we could run a small oil filled heater (put it on a protective mat as they can leak) permanently in the worst of the winter to keep the cold and condensation out.
    Now that the MH is in a CASSOA Gold storage area we don't have the luxury of the EHU but I try to visit weekly and start it, open up and spend and hour or so pottering around. I also keep a small solar panel plugged into a lighter socket (permanent live) to trickle charge the vehicle battery.
    Also consider draining down the water and waste systems if it is not going to be used for a while as freezing can damage the pipework.
  4. scousebird
    scousebird Funster
    Apr 18, 2012
    14,544
    24,006
    South East Kent
    Leave the taps open in the kitchen & bathroom and leave the fridge door open.
    We also take ours out for a run if it has been stood for more than about 2 weeks.
  5. Huffy
    Huffy Read Only Funster
    Oct 20, 2013
    England
    Hook up at home
    Most definitely yes, if you have the facility use it. We have done so for close to 40 years.
    Yes to the heater if you can afford it, a small oil filled radiator is what I use max 400w.
    Also good idea to keep your batteries fully charged during the winter and you can do that if you are hooked up.
    All the best
    Huffy
  6. Ed Excel
    Ed Excel Funster
    Nov 27, 2012
    869
    577
    Ribble Valley
    Main thing to add to the previous advice is provide some ventilation. Especially if you put some heat into the van. As the air gets warmer it can hold more moisture and that will condense on the coldest surfaces inside your van if you don't open something to let it out.
  7. Allanm
    Allanm Funster
    Jun 30, 2013
    3,139
    4,281
    Cotes d'armor, France
    Is there anything wrong with leaving the motorhomes heating on low, say, set at 10 degrees C, then at least the heater is protected.
    Allan
    • Like Like x 1
  8. Ed Excel
    Ed Excel Funster
    Nov 27, 2012
    869
    577
    Ribble Valley
    Don't see why not if it's on EHU. I've always understood 10C is the absolute minimum for protection of the fabric of any habitable space.
  9. ShiftZZ
    ShiftZZ Funster Life Member
    Feb 19, 2008
    19,812
    36,113
    Leicestershire
    Any suggestions regarding a frost watch heater?
  10. Campercaillie
    Campercaillie Read Only Funster
    Jun 23, 2012
    1,178
    2,127
    Scottish Highlands
    I leave mine on permanent hook-up over the winter months. I don't bother with any heating - even though it can get to minus 20 here when the winter sets in. We gave it its final end-of-season clean yesterday, drained it all down, and it's now under its Pro-Tech cover until the end of April. All I do is start the engine and run it for about 15 minutes every few weeks, and move it just enough to rotate the tyres. No problems. :thumb:
  11. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,275
    7,941
    West Norfolk
    It is very unlikely your 1997 Drifter has a smart charger unit. It will probably have a fixed output charger.
    A fixed output charger does not have the facility to identify when the batteries are fully charged and then stop charging them. What this means is that it will continually overcharge the leisure battery. I also very much doubt there is any facility to charge the starter battery also.
    A good idea might be to switch off your charger and only switch it on for say 24hrs a week, monitoring the batteries to make sure they are getting topped up.
    An even better idea might be switch off the vans charger and instead use a charger designed to maintain your batteries. You can leave one of these connected with no ill effects.
    Leaving a fixed output charger on constantly will ensure you need new batteries when Spring comes.:cry:
    • Like Like x 1
  12. Allanm
    Allanm Funster
    Jun 30, 2013
    3,139
    4,281
    I might raise it to 12 then just to be on the safe side. Just checked inside and the display tells me it's 18 degrees C in there.
    The insulation seems to work well
    Allan
    • Like Like x 1
  13. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,552
    7,834
    Looks like I am the only one so far that goes against this..:Doh:
    The van has a single 80w solar panel and has never been on hook up at home. Same with my last van..
    Ref heating, in almost 14 years and several vans never used a heater. They dont heat them on dealer forecourts or when at the manufacturers..
    Drain the water, leave taps open, lift cushions up and open cupboard doors...
    Or. take it to Spain / Morocco... Now thats a better idea.. :thumb:
    • Like Like x 8
  14. Allanm
    Allanm Funster
    Jun 30, 2013
    3,139
    4,281
    I like the Morocco idea, I'll get me shorts....
    Allan
  15. Peter & Elaine
    Peter & Elaine Funster
    Aug 30, 2012
    3,994
    6,500
    Roobarb land
    Same as tonka but if we going away I just plug it day before leaving to chill fridge
    500 watt oil heater just air van out
    Top window open on lowist setting
    Done
  16. PaulyP
    PaulyP Funster
    Jul 29, 2011
    1,812
    3,068
    Manchester
    I have 2 small tube heaters which are operated by a thermostatic plug. Set the temp, say 5 degrees, as as the temp drops they will switch on then switch of once it gets above the set temp.
    Thermostatic plug (looks just like a plug in timer) would operate any electric heater.
    Also take it out for a run each week.
  17. daisy mae
    daisy mae Read Only Funster
    Mar 12, 2013
    676
    596
    Leicestershire
    Last year was the first year of me having a MH, drained it down and left taps open, it is on hook up when on the drive, but as it is my only vehicle it is also used a lot. didn`t use a heater in it. I didn`t have any problems will do the same to the other one I have just bought.
  18. Ralph-n-Bev
    Ralph-n-Bev Funster
    Nov 30, 2009
    5,982
    9,177
    Wrenthorpe, Wakefield.
    We keep ours in storage. Outside. But we use it throughout the year.
    So the weekends when we aren't away and through the week whilst at work , we just drain water, open taps , open all cupboards.
    We don't have copious amounts of tat ,junk , or clutter in the MH. Only quilts , a couple of waterproofs , wellies , fleeces. The rest of the stuff we need , we take with us when we pick up the MH to go off on our trip. We used to do the same thing with all the caravans we've had in the past too. So far , we've never suffered mould or damp in anything.:thumb:
  19. DAVWOD
    DAVWOD Funster
    Sep 23, 2013
    106
    33
    Staffordshire
    Hook up but can't at Home
    For someone who can't hook up at home (that would be me) would I have to take the batteries out and charge as you would a car battery .. :Eeek:
  20. DAVWOD
    DAVWOD Funster
    Sep 23, 2013
    106
    33
    Staffordshire
    Age is just a figment of one's imagination - until you look in the Mirror :Wink:
