Home Storage - driveway chippings (1 Viewer)
Feb 5, 2009
678
783
South Essex
15 in MH, 15 in Caravan
Hi everyone
I keep my van in the back garden and it currently stands on a grassy patch in the corner.
Well the weeds & grass cutting is bit of a pain, so was thinking of putting down some chippings
So, any advice on what chippings I should use please? I see in France that they use a fine cream coloured type successfully, but have no idea what it is
Any advice gratefully received
Steve
treetops1
1,599
1,759
yorkshire/ lincolnshire.
Sold last van-
a long time,since 1996
Cream colour could just be lime stone .If you put stone down you first need to lay some TERAM membrane down so what ever stone you use you don't lose it .You can get small amounts off Ebay relatively cheap lol.
Nov 2, 2008
461
377
Lincolnshire
PVC, S&L Iveco
45 years
We laid a bed of hardcore and then covered it with Angular flint. Its shape means it locks together and does not squash out and move about like the round pebble stuff does.
Sep 26, 2013
4,169
5,154
Market Rasen
Self Build
Since 2003
As any builders on here will tell you to do it properly you will need to dig out around 6 inches of soil, lay hardcore, compact it with a vibrating plate and then top it off with your chosen finish.
Jul 29, 2013
9,071
18,515
Salisbury
Hymer B678DL A class
since 2011
As above but I would choose a gravel that crunches when walked on a good deterrent for thieves as they could be heard trying to pinch your hard worked for love of your life.
TheBig1
17,630
43,262
also put in a border to contain the chippings otherwise some will migrate to the lawn. then when mowing the lawn, stones can become projectiles which can easily smash glass windows and make a right mess of a motorhome
Jan 19, 2013
132
109
Worcestershire
since 2010
Hi, this is what I did to extend my front drive into the lawn area so as to drive the motorhome on to it.
Dig out the lawn to approx 8" depth. Put down approx 6" of MOT type 4. Hire a wacker plate to consolidate. Then put down approx 2" to 3" of 20mm / 25mm flint type limestone. Locks together a treat making it all very solid once driven over a few times.
This is a good time of year to do it, as the lawn / grassy patch will dig out to a nice spade depth very easily.
Ridgeway
3,656
6,151
Lausanne
NiBi Arto 85E
Since 2012
We were measuring up for something similar at the weekend, think it needs a good dig down and prep first.
Our only obstacle is informing our neighbours now....
EssexBoy
Feb 5, 2009
678
783
South Essex
Our garden (well, I call it a garden, it's a big patch of rough grass really) is solid clay earth. Even when the ground is waterlogged it's still like iron!!!! :LOL::LOL::LOL:
We're not gardeners so are more concerned with practical than pretty so the limestone chippings sounds a good shout
A quick google shows this stuff that might do the trick?
http://www.stonewarehouse.co.uk/gra...ravel-0-10mm?gclid=CPTXsISkttICFYYcGwodFBUBUg
Or this
http://www.stonewarehouse.co.uk/gra...ings-10-20mm?gclid=CPSZ3fOlttICFQEA0wod04oLiQ
I guess I'll need say four inches (10cm) deep so 8m x 8m x 10cm = 6.4 cubic metres. Any ideas on how I turn that into weight please?
Mean time thanks for all the advice so far. Much appreciated
Steve
TheBig1
17,630
43,262
Or this
Steve
given that description of the garden i would hire in a mini digger and dig down 12 inches the fill with 9 inches of hardcore followed by 3 inches of limestone. not only will it work well as a parking pad it will help drain the surrounding garden
Minxy
32,649
66,534
E Yorks
Carthago Compactline
If you don't need a drive as such but just somewhere more solid to park the MH instead of making the whole area 'heavy duty' just put 2 runs of pavers down (firmly based of course) where you drive the MH onto and then just dig down the rest a bit, put a membrane down and shingle/chippings on top ... much quicker and cheaper.
43,323
49,440
Lay gravel too deep and it moves as you drive over it leaving wheel tracks.
Gravel drives are usually just a couple of inches deep.
Badknee
7,407
412,610
notloB
Vantage Neo
Living the dream.
This stuff might help, found on eBay.
Feb 21, 2016
4,918
29,522
Uk
C class
Since 2017
Basically you need a good base of hardcore with some gravel on top.
And whatever you end up with,spray with Round Up when growth reappears
grasscutter
2,469
8,630
East Wittering. West Sussex.
Hymer Exsis i588
Started in 1980
A cubic meter builders bulk bag of sand is roughly 1 ton.....should give you a ballpark weight
Easy to underestimate quantity required. The normal bulk bag of 1 ton is about 0.6 of a cubic metre.
EssexBoy
Feb 5, 2009
678
783
South Essex
Thinking about it, you've hit the nail on the head there. I guess what I'm after is actually making this bit more manageable where the van stands.
As I said, the ground is always rock hard all year round. In two years that the van has been in this spot and driven over all year round, there is next to no sign on the ground - even the grass isn't worn!!!
I really like the idea of KISS and putting down a membrane & as thin a layer as possible of the limestone chippings, but never having done it before, I'm wary that I'll get the "no mowing", "no/not many weeds" effect I'm after...
Thanks again
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
We had a small lawn at the front of the house which was really just a nuisance as you wouldn't want to sit out there. We dug it out and had a couple of tons of blue slate chips delivered. Looks nice when the van is not there and water drains away with no wheel marks or limestone mush.
Mar 23, 2012
9,544
32,076
sleights
c class
I would put down some of the plastic reinforcement as in badknees post and gravel on top. If the area is already draining well and all you want is mud free acess why not just make a path with a few squares to the m/h doors
Mar 23, 2012
9,544
32,076
sleights
c class
I would put down some of the plastic reinforcement as in badknees post and gravel on top. If the area is already draining well and all you want is mud free acess why not just make a path with a few squares to the m/h doors or just a row of slabs
jtp890
591
393
wakefield
Dethleffs 7014
13 years on n off
If the ground is rock hard, lay some black HD polythene to stop vegetation,timber edging to contain stone, lay 100mm of type 1 sub base(Recycled crushed concrete if available) level with garden rake, roller or vibrating plate to tighten surface.No problems
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
Whatever topping stone you use suggest keeping it quite large - we had a pea shingle path & became a loo for all our neighbours cats! The delivery people & post lady weren't too impressed either as constantly dodging humps on the path :eek: No problem with larger stones like slate (does break down with use) or chardstock (very tough).
JimJams
249
377
East Sussex / Kent
RV, A Class
since 2003
Just had the front of our property done and wanted the cream colour without the golden flint coming through which is commonly used, so went for the:
Yorkshire Cream...
Purchased through a company called Gravelmaster online. Its 20mm variants so wont get stuck in the tread of your tyres and spread down the road everytime you leave the driveway!
Honestly looks really good and not stupid money!!
EssexBoy
Feb 5, 2009
678
783
South Essex
Thanks everyone.... Will consult the boss for further instructions on final choice of materials :LOL::LOL::LOL::LOL::LOL:
