Hole cutting (1 Viewer)
Bart
3,188
1,396
Northern Ireland
Boxer L4H2 van build
Since 2016
Have to butcher the outside of our MH and cut a few holes so want advice on the best way to treat the bare areas to prevent corrosion.
First up is 2 dead locks getting fitted to the front metal doors , so whats the best way to treat the bare exposed metal.
Second up is the Gas it re filler which is getting a hole drilled in the Aluminium skirt. now i know that aluminium does not rust but it does corrode which causes the paint to come off and the corrosion spreads, so again whats the best way to treat this bare area.
Bart
Bart
3,188
1,396
Northern Ireland
Since 2016
It won't be seen.
lol it might be seen as you have never seen me cutting holes before :D ,, fk i'd better not joke in case it goes like this .... Trevor to wife .... " Hi Elaine i've had a slight error in installing the dead locks in our MotorHome as in you now have a free air con hole in your passengers door as i drilled a hole in the wrong place :D :D
43,207
48,811
Mm!! Might be worth getting a grown up to drill the holes then. ;)
Peter A Forbes
270
184
Rushden, Northants, UK
Mercedes 614D
Use a good quality hole saw in the first place, then invest in a can of U-Pol acid etch primer to treat the edges after to have cleaned the burrs up with some wet and dry. The acid etch works on aluminium and steel.
I give it two coats of primer then top coat as needed.
Peter
