High Sided Overcabs + Stability (1 Viewer)
joggerman
139
6
Lancashire
Just Looking
Since 2004
I am still deliberating over which next motorhome to buy, but I am leaning towards a Euramobil 580LS Profila.
My only concern is that it is all 'slab-sided' including the enormous overcab pod, plus it has a double floor which further raises the sides of the van.
My question is how are such vans affected by side winds?
Toffs-G
610
120
West Sussex
Adria Twin 640SPB
September 2009
I have an Elnagh that does have a large overhang (not sure difference in relation to what your considering) however,i have not found the size to be much of an issue and have driven in some windy conditions, obviously yes it does catch side winds but I must admit since having it not to the extent I was expecting.
I have considered having air suspension fitted whcih I understand stabilises the MH but as yet I haven't found it that critical to warrant the expense.
Elbagh is quite high and does not have the lower build and wider axle of some (as Elnagh is a bit of a budget MH I guess although very good excellent winterising) and I do not find the stability an issue I tend to drive at around 65mph on motorways. Yes you will feel the trucks etc but not to a critical extent and certainly so far has not detracted from the enjoyment.
Sorry if I have waffled a bit but hope it helps
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
I've never seen one blown over.
I think it feels very much worse than it is and I've never felt out of control in gusting winds. The usual comment is "Thank god we aren't on the bike".
bill2b
120
Lincoln
Hi Top
No problems to report with ours.
Sometimes in strong winds you get a blast if a lorry goes past the other way but you would get that in any vehicle.
We have air suspension but not dabbled with it yet because it works as it is.
:Smile:
Jaws
23,836
72,460
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Got one of the larger ones myself. Not as big as a tag but about as big as you can go without !!
Been all over the place in some fairly heavy winds and never once had a problem
The only thing I have ever suffered is the FEELING I was vulnerable.. but it was def 100% nothing more than self doubt as I asked woman after the gusts died down if it had concerened her..
The reply?
Had WHAT concerned her !! Kinda sums it up methinks :Smile:
