hi im bill from ambergate. been mtorhoming 4 2 years.
Discussion in 'Introduce Yourself' started by bill baty, Oct 21, 2014.
  1. bill baty
    bill baty Read Only Funster
    Oct 21, 2014
    ambergate derbyshire
    can anyone help me with a problem with the sidelights on my swift bolero 724fb.
    when i switch them on the nearside front and back go off after 1 second. many thanks if u can help.
  2. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,907
    39,959
    Hi Bill, and welcome... (y)
    My first port of call would be to check fuses and wriggle a few wires...
    Sounds a simple fix,,,, but got to find out why first..
    Good luck..
    • Like it Like it x 1
  3. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,745
    10,163
    not a simple fix sorry. the body control ecu is detecting a higher current drawn than expected so switches off the circuit to protect it. often turns out to be a corroded connector on the wiring loom. the only answer is a proper auto electrician or many hours trial an error under the van
    • Like it Like it x 2
  4. irnbru
    irnbru Funster Life Member
    Jun 27, 2013
    5,953
    11,208
    Glasgow
  5. movan
    movan Funster Life Member
    Dec 2, 2009
    13,958
    25,397
    Moving around
    Hello and welcome. :)
  6. Shazrick
    Shazrick Funster
    Oct 16, 2013
    876
    234
    Lincolnshire
  7. scotjimland
    Jul 25, 2007
    28,938
    25,624
    Hi and welcome..
    it sounds like an earth fault to me.. I would check the nearside rear light cluster first , you may find it is wet and or corroded.. and simply needs cleaning drying out .. a sign that it may be suspect is moisture on the inside of the lens.
    if that is ok, the next suspect is under the rear of the van.. convertors extend the existing loom, look for a square joint box, same procedure.. look inside for dampness and dry out and repair renew any suspect connectors..
    If that is OK look at the front light .. unlikely but not impossible for it to get wet due to a cracked lens..
    If still no luck you may need to consult an auto electrician
  8. dabhand
    dabhand Funster Life Member
    Feb 19, 2014
    1,559
    2,770
    Staffs
    Hi, welcome to the forum, enjoy your travels. Had a similar problem on my Hymer after I took the hydraulic motorbike carrier off, the earth to the lights was using the steelwork, corroded wires etc, remade the earths and all working, have you changed anything on your van? Any the tech guys will be along soon good luck.
  9. dabhand
    Feb 19, 2014
    1,559
    2,770
    Staffs
    See what I mean! what a funtastic forum this is:)
  10. ukbill
    ukbill Funster
    Nov 3, 2011
    4,969
    4,899
    benidorm
    same thing happened to me twice bill and it was a broken earth wire just needs to be checked bit by bit to find the break
  11. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,363
    5,614
    Guisborough
    Hi Bill
    42 years wow.
    OOPS 4 2 years, sorry.
  12. Momo
    Momo Funster
    Sep 19, 2008
    2,467
    3,000
    Valencia City, Spain
    Hi Bill and welcome to the Fun!(y):welc:
  13. PORKSTER
    PORKSTER Funster
    Sep 15, 2009
    1,015
    1,045
    Sussex coast
    An autoeletrician once told me 90% electrical issues are bad earth issues. Good luck hope you can fathom it out your self
  14. cruiser
    cruiser Funster Life Member
    Sep 12, 2012
    3,020
    2,863
    northampton
    hello and welcome to the house of fun.
  15. bill baty
    Oct 21, 2014
    first of all thanks for the welcome. and yes it is 2 years.
    also thankyou for help with the problem ive got, i think an auto electrician is the best bet.
    Good luck and thankyou everyone, ps HAPPY XMAS!!!!!!!!!!!!!!
  16. Bailey58
    Bailey58 Funster Life Member
    Jun 23, 2010
    6,658
    10,335
    Norfolk and Toftir.
    Welcome bill from ambergate. We've got to make sure we don't confuse you with Ambilkate. :laughing:
  17. Al-Di
    Al-Di Funster
    Mar 15, 2014
    1,015
    4,063
    prestwich
    Welcome,
    Alan + Diane,
  18. simsy56
    simsy56 Funster
    Nov 6, 2008
    3,101
    13,456
    Ramsey, Isle of Man.
    Welcome to the forum. I know Ambergate well. My Brother and my dad live up the road at Matlock, and Darley Dale. My last home there was Watnall. Lovely part of the country.
    Craig
  19. Ambilkate
    Ambilkate Funster Life Member
    Jul 15, 2009
    4,728
    8,510
    Shropshire
    Hi Ambergate welcome to fun from us three :) :) :)
