Hi Good People !!
Discussion in 'Introduce Yourself' started by barneythebear, Mar 3, 2010.
  1. barneythebear
    barneythebear Read Only Funster
    Mar 3, 2010
    16
    lincoln
    Hi there ,
    Im Barney and i have a 2004 swift sundance 630l which i would like to get away more often in !! unfortunely i have a plumbing problem at the moment , when i turn pump on
    i have a water leak coming from under the bathroom compartment ! i cannot see where the leak is to fix it ..there is three cold feeds coming off the pump which all run under the bathroom plastic one comes out the other side and runs to boiler one goes to cold bathroom tap and i think the other one runs to the toilet not too sure !
    so i am wondering has any one got any advice how to remedy this problem please
    thankyou :cry:
  2. chatter
    chatter Read Only Funster
    Aug 3, 2009
    3,723
    940
    cheshire
    Hi and welcome
    Im sure some of our guys will point you in the right dirrection shortly
  3. barneythebear
    Mar 3, 2010
    16
    lincoln
    Thanks chatter fingers crossed :thumb:
  4. Big Ed
    Big Ed Read Only Funster
    May 4, 2009
    54
    Derby
    Hello Barneythebear and welcome.
    Regarding your plumbing problem. How much water leaks out when the pump is switched on?, if it is a massive amount it probably means that the frost has blown the pipe out of the fitting. These plastic fittings just push back in if this is the case. Otherwise it looks like the plastic pipe has burst due to frost.
    In either case you will need to gain access to the pipework which could mean removing the shower base.
    Hope this helps.:Wink:
  5. barneythebear
    Mar 3, 2010
    16
    lincoln
    Hi Big Ed ,
    Thanks for replying back , There is a quite alot of water , trust it to go in a place like that means i am going to have to take the sink and the loo out to take the base out , the shower tray was split anyway ! oh well its my own silly fault .i will winterise it next time for sure !!
  6. hilldweller
    Dec 5, 2008
    27,885
    26,962
    Macclesfield
    It's so easy for this to happen. Just parked at an angle and a pocket of water and that's it.
    I had to dismantle my Burstner shower due to frost damaging the shower valve. Lots and lots of screws and I got to the back of it, bit of super glue, sorted. I even finished with no screws over. Luckily all the joints overlapped with no sealant so it was a nice job.
    I hope you get so lucky. But worst case is a long term leak, floor soft, which is why the shower tray cracked, look long and hard while you are in there.
  7. barneythebear
    Mar 3, 2010
    16
    lincoln
    thanks brian glad your up and running again !! i will look hard :Sad:
  8. barnybg
    barnybg Read Only Funster
    Jan 23, 2010
    93
    Bulgaria/Greece/Turkey/Wa
    Water ? and HI !!
    Hi Barney,from another (Barny) i had a similar problem,unfortunately you have to dismantle the fittings,but try looking at the pipes going straight into the taps,if your lucky like me,one of them came loose and away,thats all ! half hour later,all was well,but you may as well check WHY that shower tray is cracked and maybe replace,checking floor area while your at it ,good luck.
  9. barneythebear
    Mar 3, 2010
    16
    lincoln
    Hi Barney ,
    Great name that lol , I already checked the cold water tap in the bathroom
    does the other cold feed go to the loo ?????? only one comes out the other side of the wall with the returning hot feed for the hot tap in the bathroom (three cold feeds from pump)
    regards :Doh:
  10. bald eagle
    bald eagle Read Only Funster
    Jan 30, 2009
    528
    4
    here,there and everywhere
    How barney and :welcome:
    regards
    bald eagle:thumb:
  11. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,427
    5,457
    East Sussex 01-580-881288
    HI,
    Your welcome to ring my lads in the workshop and pick their brains, ask Glenn or Ian.
    The shower tray if you do replace it, make sure you put additional packing underneath it. Might be repairable with a fibre glass kit with strips underneath, certainly a lot cheaper.
    Peter
  12. barneythebear
    Mar 3, 2010
    16
    lincoln
    Thanks for replying i will take u up on your offer to ring your lads thankyou
    i am not too worried about the shower floor really i just want to make the pipes under
    it accessable so i dont have the problem again cheers ..
Similar Threads
  1. easy
    19
    194
  2. CamR
    14
    157
  3. littledrover
    15
    198
  4. Jo-j
    16
    169
  5. Tam
    15
    269
