Hi All , Newbie Calling !
Discussion in 'Introduce Yourself' started by Chriffy, Jul 23, 2012.
  1. Chriffy
    Chriffy Read Only Funster
    Jul 23, 2012
    6
    Cottenham
    Hi,
    new to all of this, been hankering for a motorhome for as long as I can remember ( at my age thats a long time) , finally done the deed and gone for a 2007 A Class Burstsner Elegance i685.
    Had two short trips so far , just to get used to things and write the list of things we forgot to get !!!
    Looking forward to many more trips in the not too distant future.
    I'm sure I will have numerous questions and hope you can all help me out along the way.
    Chris
  2. steveclecy
    steveclecy Read Only Funster
    Jun 10, 2009
    885
    582
    Wirral
    Welcome to the Forum. I am sure you will have no regrets.
    Steve
  3. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Cleveleys,Lancashire
    Hi :flyingwelcome::flyingwelcome:
    Pete :thumb:
  4. f6c
    f6c Funster
    Nov 7, 2010
    3,231
    865
    gloucestershire
    welcome
    Welcome aboard:Wink:
  5. JJ
    JJ Funster
    May 1, 2008
    14,741
    26,319
    Welcome to the Fun Chris...
    Well impressed !
    Nice posh van... :thumb:
    JJ :Cool:
  6. PaulyP
    PaulyP Funster
    Jul 29, 2011
    1,812
    3,066
    Manchester
    Get in touch with Jim (the ringleader) and find out where you can download the motorhome checklists, you wont forget anything again.
    Worth it for a newbie.:BigGrin:
  7. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,572
    5,651
    Near Mold North Wales
    :welcome:
  8. FIDGET
    FIDGET Funster
    May 7, 2011
    2,927
    6,050
    Isle of Wight
    Hi and Welcome from the Isle of Wight. Terry:Cool:
  9. The wizened of OZ
    The wizened of OZ Read Only Funster
    Jan 20, 2012
    159
    241
    Brisbane Australia
    Gday
    :welcomefunster:
    • Like Like x 1
  10. Chriffy
    Jul 23, 2012
    6
    Cottenham
    Burstner Elegance i685 Water pump
    Hi all, your superior knowledge would be appreciated........
    When i turn my pump (water) on at the control panel it seems to be continually pumping. Is this right? Should it not be activated by the micro switches in the taps/shower/flush toilet ??
    Do I rteally have to turn it on and off every time I wish to use it??
    Yopur help / advise would be grratly appreciated.
    Chriffy
  11. Chriffy
    Jul 23, 2012
    6
    Cottenham
    Please ignore spelling errors!!!!!
  12. Loujess
    Loujess Read Only Funster
    Jan 10, 2010
    3,261
    3,168
    Leeds UK
    Hi Chriffy and welcome. The only time our pump kept going was when we had a leak, under the sink in the bathroom. You may need a new tap or connection, but I'm sure others will know more. I'm sure there's a motorhome parts dealer near to you. :welcomefunster::welcomefunster::welcomefunster:
    Ivy
  13. Chriffy
    Jul 23, 2012
    6
    Cottenham
    Thanks Ivy, didn't think it was right, I'll need to investigate further,
    Chris
  14. lorger
    lorger Funster
    Jul 11, 2008
    6,270
    7,729
    Dumfries
    Hi Chris
    Your pump should only be running when using the taps so as Ivy says you may have a leek, or if you have the mixer tap like ours if it isn't pushed down properly it can activate the switch which in turn activates the pump even though no water comes out.
    Hope this helps
  15. Styx
    Styx Read Only Funster
    May 1, 2010
    572
    2,970
    Buckinghamshire
    A couple of simple things to check from our experience -
    if the pump continues to run on the current van (Rapido) it probably means that 'someone' has drained the boiler (or the boiler has dumped because of the outside temperature - not relevant at the moment) and forgotten to close the dump valve - you'll see water under the van if this is the case
    if the pump continued to run on the last van (Autosleeper) it probably meant that one of the taps hadn't been turned off tightly - even the slowest drip would activate the pump
    Hope this helps
  16. DesRes
    DesRes Funster
    Apr 21, 2012
    260
    110
    West Lancs
    Hi Chriffy,
    Congratulations on your new motorhome.
    In addition to what others mention:
    If the pump is continually running and there are no leaks and the whole system is fully primed then the pump may not be attaining the cut out pressure. You might still be getting water out of the taps so it is pumping something. If you have good pressure at the taps then it may be a faulty microswitch. The microswitches are normally incorporated in the pump unit so either way it could mean a new pump. They are easily attainable from caravan accessory stores and relatively straight forward to fit if the access is good. Hope this helps....:thumb:
  17. Pikeman
    Pikeman Funster
    Nov 6, 2011
    285
    318
    Worthing
    Wow!!! Nice van to start with.:Smile:
  18. Chriffy
    Jul 23, 2012
    6
    Cottenham
    Hi DesRes,
    thanks for advice. Replaced pump 2 weeks ago as it had failed, dealer sent me a new one, easy to fit.
    Micro switches seem to be in the taps, I can hear them when the taps are lifted into "on" position. There are no apparent leaks anywhere and the system is fully primed. a mystery.
    Can't really find anything in the manual that helps, so may just send an email to Burstner to see if they can offer advice of any kind.
    Thanks to everyone for the help and advice so far, you've been great,
    Chris
  19. DesRes
    DesRes Funster
    Apr 21, 2012
    260
    110
    West Lancs
    Okay Chriffy,
    Different system, and I've never worked with the one you have....:Sad:
    However, if you have microswitches on all the taps in the van, logic says that it must be one of those micro switches that is continually telling the pump to start, whether the tap be open or closed. (It is only by cutting the power to the pump that you are getting it to stop, yes?)
    I am guessing that each tap in the system will have it's own micro switch and all the switches will be wired in parallel so that no matter which tap is operated then the circuit is closed and the pump will run.
    So how to find which tap switch is at fault? If the terminal connections for each tap switch are accessible, first of all turn off the power and disconnect one switch, (remove the two wires that will come from the tap to the junction.) Switch the power back on and if the pump starts then it's not that one, but there may be more than one at fault so leave that disconnected and move to the next. By process of ellimination you should find it. If you have a multimeter to hand you can check for continuity on each switch, zero resistance with the tap open, open circuit with the tap shut. This will really test the switch mechanism of each tap.
    Now, I'm only guessing all of this so if none of it's true I'm quite prepared to get shot down. Don't do anything if you are unsure....:thumb:
  20. Chriffy
    Jul 23, 2012
    6
    Cottenham
    Thanks yet again DesRes,
    Sounds very logical to me, and a worthwhile exercise if only to eliminate the micro switches as the potential problem . That's my Saturday morning sorted then !
    Cheers,
    Chris
