Hi All help
Discussion in 'Introduce Yourself' started by lonsdale, Jan 21, 2011.
  1. lonsdale
    lonsdale Read Only Funster
    Jan 21, 2011
    5
    sussex and spain
    Hi all I am new to this so please go easy on me...can anyone tell me why the water pump keeps going when the taps are turned of only had the camper 9 weeks.
  2. Janine
    Janine Funster Life Member
    Aug 22, 2007
    4,950
    8,043
    Sunny Shropshire
    Sounds like you might have a leak in the system - the pump's dependent on water pressure to operate.
    Oh and welcome to the forum!
  3. grumps147
    grumps147 Funster
    Jun 6, 2010
    1,235
    883
    St.Helens
  4. grumps147
    grumps147 Funster
    Jun 6, 2010
    1,235
    883
    St.Helens
    sorry
    welcome, if you use the search feature its very good indeed
  5. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    hi and welcome to the site. As already stated you have a drop in pressure someplace, tighten all connections and look for drips, sometimes air gets in without water getting out, but not often.
  6. wivvy's dad
    wivvy's dad Read Only Funster
    Jun 22, 2010
    3,218
    1,807
    48.066895,12.862673
    As has been said above, you have a leak of some sort.
    I had that t-shirt for a couple of minutes last year.................:Wink:
  7. lonsdale
    Jan 21, 2011
    5
    sussex and spain
    have looked all over for a leak and cant find one the only way i can stop the pump running is to turn of the power at the control board there is plenty of water in the tank.
  8. lunarman
    lunarman Funster Life Member
    Sep 23, 2008
    1,471
    883
    South Glos
    Hi and Welcome,
    Assuming that water runes when you open the tap and there are no leaks it sounds like the pressure switch on the pump is faulty.
    What van is it by the way
    Lunarman.
  9. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    You will have a leak, probably around the push-fit joins, or unions to taps. Hardest to see will be the sink tap, which usually will pour water behind the cupboard or behind the fridge. Tell tale signs and water on the floor (without you actually spilling any) or if you look at the pilot light viewer inside the fridge, that will be condensated.
    Shower taps are easily checked; nest will be the heater cistern/tank. There are a few unions around here - but firstly check that the drain plug is in tight, and the top vent closed outside. Then check the drain inside. Then check the unions for leaks from the tank, to the heater and from there onwards.
  10. lonsdale
    Jan 21, 2011
    5
    sussex and spain
    It a Pilote Galaxy on a Mercedes
  11. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
    do you have air in the system that needs bleeding?
    is the water heater drain shut
  12. davejen
    davejen Funster
    Aug 21, 2008
    1,260
    715
    Kirkpatrick Fleming Dumfries
    Hi, could be the diaphragm in the pump- this will let pump run but not pump water, has it frozen up in the recent cold weather? this could cause the pump to freeze and tear the diaphragm when you switch it on.
    Hope this helps, cheers Dave:thumb:
  13. lonsdale
    Jan 21, 2011
    5
    sussex and spain
    Thank you all for your help i will have to have a good look in the light once again thank you all:thumb:
  14. johnp10
    johnp10 Funster
    Oct 12, 2009
    7,638
    14,305
    North Lincolnshire
    Hi and welcome.
    I had the same problem with a fiamma pump, same symptoms exactly.
    No leaks anywhere.
    Changed the pump...sorted.
  15. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    could be a faulty micro switch on one of the taps if it has that system on
    some are pressure operated ie you open a tap the water pressure drops then a switch on or near the pump turns on the pump
    some have switches under the taps which operate the pump when you turn on the tap
    if on the second type the taps will click as you open them so if 1 doesn't click where as the others do that would be the first place to look
    although some manufacturers use switched taps on the pressure system so the taps may click anyway.
    hope this helps
Similar Threads
  1. Mark Smallridge
    18
    109
  2. Pos
    13
    154
  3. KarlA
    14
    139
  4. Jayel
    18
    212
  5. Hezza
    7
    148
