Hi all another scalp for you all
Discussion in 'Introduce Yourself' started by rambler, Jul 26, 2009.
  1. rambler
    rambler Read Only Funster
    Jul 26, 2009
    8
    North West
    I now that I should have looked for forums first, but the headache I have with me Merc based Scout is a nightmare and just hope help may be at hand here.
    She is a 01 316cdi that sometimes will start and others not off the key that is. The is no errors on the dash ie start error warning. But just wont crank over a feed from the battery to the solenoid and away she goes.
    The local dealer RR have been out and are unable to trace any fault!? I think there is a relay somewere as when she wont fire there is only 3v at the solenoid not the 12 needed.
    Plus RR damaged a side window so on the look out for that also.....:cry:
    Any help will be welcomed with open arms, but now to reading the site:RollEyes: Looks good btw
  2. DESCO
    DESCO Read Only Funster
    Mar 11, 2009
    2,651
    267
    London
    Hi Rambler WELCOME to the fun.
    Don't know much about Mercs, but years ago had a fault that sounds very like yours on an old Astra. What the garage found in the end was in the wireing. What had happened was in making the wire conection there was a break in the wire inside the insulation. Over years this had slowly burnt away inside, without showing trace on the outside. Don't know how they found it but you could pull the wires out of the insulation.:Eeek: Sometimes it worked sometimes not. They had never seen it before.
    Just a thought
    Dave
  3. johnandcarol
    johnandcarol Deleted User
    Sounds like an alarm/fob fault to me!
  4. rambler
    Jul 26, 2009
    8
    North West
    Sorry should of said there is no alarm and the fob \ imob is fine as she fires. if it was down then it would just turn over and over.
    The sender for this has already been checked
  5. bald eagle
    bald eagle Read Only Funster
    Jan 30, 2009
    528
    4
    here,there and everywhere
    Hi rambler and :welcome: good luck with your merc.
    regards
    bald eagle
  6. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    Hi and welcome to the site, the sprinter based mercs are showing all sorts of problems and it is often down to an ECU problem, good luck hope you get it sorted out.
  7. ginge61
    ginge61 Read Only Funster
    Oct 29, 2007
    431
    n/wales
    go to a fourm called club 80-90 and look for a guy called mercdoctor he does loads with sprinters :thumb:
  8. Peter S
    Peter S Funster
    Jul 20, 2009
    68
    13
    Towcester
    I would take it to your local diesel specialist. Not sure where you are, but there are about 300 around the country, most of which have a drive in facility. Go for one with bosch diagnostics capability as they will want to read the fault look up table and will need a proper diagnostic tool such as something called a KTS.
    good luck
  9. bazfergy
    bazfergy Read Only Funster
    Apr 20, 2009
    566
    3
    dumfries scotland
    Hi rambler i think i suffer the same with my merc 03 plate it starts with jump leads on the key sometimes please let us know if you manage to resolve the problem and we will do likewise:thumb:
  10. staging lady
    staging lady
    Nov 12, 2007
    1,134
    55
    North Wales in the Hills
    Hi and welcome.
    lucille
  11. davejen
    davejen Funster
    Aug 21, 2008
    1,262
    718
    Kirkpatrick Fleming Dumfries
    Hi, and welcome ,Rambler. I have a 99 merc 412 based Mirage- not the CDI and it sometimes does the same thing but I've narrowed it down to not taking the key out after switching off. Sometimes if I try to start it again- nothing- so I turn it off again and take the key out, put it back in and it starts! No faults shown on recent diagnosis check I had for another problem so I just live with it. Good luck with yours.
    Regards, Dave:thumb:
  12. rambler
    Jul 26, 2009
    8
    North West
    Hii all, thanks for the welcomes and replies:BigGrin:
    For a bit of a update. It seems that the ignition switch is at fault and am now trying to source a replacment, but have been warned that the key may need coding to it and that is not cheap.
    I dont know if anyone has ever dealt with "Magnum Motorhomes" in Grimsby, but there service and advice given to me, has left me blown away. The had a new window for me (when I say new, its never been fitted) 1270x530 £85 delivered!!!! very good deal I think, just fitting it now is going to be the pain, waiting for a break in the weather. Just wish I could bill RR.
    It does have the wrong top hinge so am having to change that also, but got that from a place I pass every morning and never gave a thought to, until someone mentioned them "Widnes Caravans".
    Just 1 day I will have my eyes open and see what I need from the get go.
    Thanks all, speak soon
  13. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,900
    13,930
    Norfolk
    Hi Rambler cant help with fix but welcome
