HHO Generators
Discussion in 'Motorhome Chat' started by Braunston, Aug 1, 2008.
  1. Braunston
    Braunston Read Only Funster
    May 21, 2008
    1,415
    7
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,320
    YO11 2BD
    looks a bit more substancial than the last one posted on here.
    lt looked like a jamjar with some tubes.
    personally i'd sooner spend me dosh on the shiny red klaxon horn next to it. :Rofl1::Rofl1::Rofl1:
    143 miles extra per tank..........that works out at around 15mpg extra.......if you beleive that i'v got some moonrock that tastes like chedder cheese if you wanna buy some....:Doh:
  3. olley
    olley Funster
    Jul 29, 2007
    3,746
    2,189
    Ipswich
  4. johnsandywhite
    johnsandywhite Read Only Funster
    Jul 29, 2007
    2,348
    15
    Doncaster/Spain
    :Cool: After spending thousands of pounds on LPG conversion. I investigated this SCAM thoroughly. I saved myself $49.95 by NOT buying into it.
    Hydrogen power DOES work. Water power does NOT. Not as much as they try to convince you anyway. :Rofl1:
  5. Braunston
    May 21, 2008
    1,415
    7
    Hi,
    When i first saw this I hadn't noticed any body selling anything it just appeared that these were just a lot of enthusiastic people who had made up their own gadgets, so at the time i really couldn't see any real scam as it didn't appear anyone was asking for money,
    While i perhaps agree with the general consensus that it probably won't work, the principal of injecting an extra fuel into the combustion cycle of a diesel engine has already been established on LPG conversions of diesel engines which does provide a small increase on mpg albeit i personally think the conversion costs are prohibitive .
    I think on balance i won't be taking the HHO route albeit if the injection of LPG into the air intake of a diesel engine works then why wouldn't Hydrogen ??? assuming that the devices they have made can separate the Hydrogen from the water ??
    I suppose the main problem would be choosing the correct grade of mineral water ?? and we all know the price of those ? LoL:Rofl1::Rofl1::Rofl1:
  6. olley
    olley Funster
    Jul 29, 2007
    3,746
    2,189
    Ipswich
    Hi Braunston, they reason it doesn't work is because it uses more in petrol to generate the electrical power needed to produce the HHO than you get when you feed the HHO into the engine.
    If this wasn't the case then you could simply run on HHO with a big enough HHO generator without using any petrol.
    Olley
  7. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,259
    5,240
    East Sussex 01-580-881288
    :shout::shout::shout::Eeek::Rofl1:
  8. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,753
    3,254
    Eastbourne East Sussex
    I fitted one of these contraptions to a elderly Triumph herald about 30 years ago when they were in vogue. The theory was that the water mist in the manifold would be turned into steam by the heat of the engine giving a bit of extra expansion in the combustion chamber. It did actually appear to give slightly more MPG (nearly 50p a gallon then!) but no way was it claimed to produce any hydrogen. There was a certain logic to it as it was effectively using surplus heat from combustion which would otherwise be wasted. I don't think I'd like to try it on a modern engine though!
  9. Braunston
    May 21, 2008
    1,415
    7
    Hi, Olley
    So are you saying it does actually work but the economics of the principal are not cost affective, e.g. its assuming perpetual motion principal is possible ??
    Only i wasn't sure if the actual contraption that they were showing would actually do anything ??:Eeek::Eeek: are you suggesting that the contraption does work ?? and it would produce Hydrogen and that if Hydrogen was injected into the the air intake, assuming it could be produced freely it would actually increase the mpg ??
  10. johnsandywhite
    Jul 29, 2007
    2,348
    15
    Doncaster/Spain
    :Cool: YES., It DOES Work:-
    CHEC HFI Hydrogen Fuel Injection system reduces emissions and improves engine efficiency, reducing fuel consumption while producing more power. It works with your truck, right now.
  11. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    once a battery is charged the alternator is still running with power to spare, no additional power is needed, so this argument does not hold water, hee hee, besides the contraption is intended to supplement fuel only not replace it. Not sure what gains there are but is a fact that browns gas is produced and will burn. Only time will tell. This idea surfaced in the 1950's and the patent was bought and shelved by the fuels companies. So nothing new. Why would the fuel companies spend such vast sums to bury it.
  12. olley
    olley Funster
    Jul 29, 2007
    3,746
    2,189
    Ipswich
    Hi wildman, you are incorrect, the alternator is running but any draw of current from it requires power from the engine. you can't get power from an alternator without putting power in, usually only about 80% or more of the power you put in.
    According to the web, elecytrolysis is only about 50% efficient, the other 50% of the power is converted into heat, which seems to indicate that the glass bottles they are using would better employed for making tea rather than gas. :BigGrin:
    "Their ain't no such thing as a free lunch"
    Olley
  13. oldun
    oldun Read Only Funster
    Mar 23, 2008
    748
    160
    St Neots
    The two short clips prove nothing. For all we know the container could actually contain hydrogen and nothing else.
    You must understand the basic principles of energy conversion. Energy out of a device must always be less than energy in as you cannot create energy only change its form.
    So though such a device may create hydrogen it will absorb more energy than it creates. There are hundreds of device that simply clip to an engine that have spiel such as "increase power by over 30% and improve fuel consumption by 50%".
    They do not exist in reality otherwise they would be in general use by all manufacturers today.
    dream on.
    This dream ranks alonside such as ceating gold from base metals.
Similar Threads
  1. Justin74
    10
    376
  2. Mart grump
    32
    1,123
